Old 03-13-2008, 11:28 AM   #1
ajgriffin
ajgriffin's Avatar
6 piston discs???
Is anyone running 6 piston disc brakes? If so who supplied the caliper and did you have to do anything special to hook it up? I've tried all of the major suppliers that I'm aware of (Baer, Wilwood, Brembo, & CPP) and come up empty.
ajgriffin is offline   Reply With Quote
Old 03-13-2008, 07:06 PM   #2
LMDGUY
LMDGUY's Avatar
Re: 6 piston discs???
did you try Stainless Steel Brakes? I thought i remeber seein some on ther website
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 03-13-2008, 07:50 PM   #3
Orange
Licensed to Thrill!
Orange's Avatar
Wilwood shows some here:
http://www.wilwood.com/BrakeKits/index.asp
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 03-13-2008, 08:30 PM   #4
ajgriffin
ajgriffin's Avatar
DLB
Those brakes are only compatible back to a 99 Silverado and they only have 6 & 8 lug applications. When I called Wilwood they said that they were in development with CPP on an application for the 67-72 C-10's, but the guy didn't have any more detail than that -- neither did CPP tech support.
Also, didn't see anything by SSBC.
Old 03-14-2008, 08:18 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
CPP should be along any time now, as well as another well known manufacturer that retro-fits Corvette brakes. They allow you to use the C6 Z06 brakes on stock or dropped spindles...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-14-2008, 08:25 AM   #6
SCOTI
SCOTI's Avatar
Initial fit from that other "well known manufacturer" looks positive.
I sent a few observations (read.... "I wish this ...."). This was just the 2-piston 40mm floating calipers & 13.4" rotors though. Theoretically, the larger 14" Z06 stuff should be easier to adapt because everything is moved further out from the spindles C/L. I didn't have the coin for 14" rotors & they would have been overkill for my beater anyway.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-16-2008, 01:42 AM   #7
7T7
Regular guy
7T7's Avatar
I had some of those 6 piston corvette calipers sitting around and put them on my 2 piston Baer set up.
From what I can tell....... Once Scoti's guys get the hubs on the market it should be pretty easy to adapt to the 6 piston, 14" rotors.
The only problem we have ever encountered with these big corvette calipers is the wheel fitment.
The calipers are so fat they hit the wheels spokes. We fix this with a 3/16 spacer in most cases but I'm sure there are wheels out there that will not have this fitment problem.
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
Old 03-16-2008, 02:16 AM   #8
SCOTI
SCOTI's Avatar
Originally Posted by 7T7 View Post
I had some of those 6 piston corvette calipers sitting around and .....
Had a set just sitting around????? What platform is your Baer system based on C4 or C6? Care to list the particulars?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-16-2008, 03:10 AM   #9
LMDGUY
LMDGUY's Avatar
I had some of those 6 piston corvette calipers sitting around and put them on my 2 piston Bear set up.
nice.. that what im gonna need for my truck
2013 Silverado
1964 Cadillac
Old 03-16-2008, 11:40 PM   #10
7T7
Regular guy
7T7's Avatar
Baers GT And GT-Plus use the PBR C5 calipers.
That big 6 piston PBR caliper has the same mounting hole spacing as the C5 caliper. If I remember the holes were like 3.5 center to center.
'Frank'
77 Silverado
Old 03-16-2008, 11:54 PM   #11
7T7
Regular guy
7T7's Avatar
Ok they were sitting around but belonged to a 2002 chevy truck at the shop..... I reluctantly had to give them back.........but I had to keep them a few extra nights and hold them while watching TV.
'Frank'
77 Silverado
Old 03-17-2008, 08:02 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Did you have to clean them off before you gave them back....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-17-2008, 08:26 AM   #13
68 short step
so where is the best/cheapest place to get the front and rear baer setup (with the c5 components)??
68 short step is offline   Reply With Quote
Old 03-17-2008, 09:02 PM   #14
LMDGUY
LMDGUY's Avatar
I usally buy direct from Baer.. talk to Bill he is a good guy with lots of knowledge
2013 Silverado
1964 Cadillac
Old 03-17-2008, 09:35 PM   #15
SCOTI
SCOTI's Avatar
P/N & price?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-17-2008, 11:44 PM   #16
abadsvt
abadsvt's Avatar
I am going to be running the C6 ZO6 brakes. I was curious to see if the brakes will fit with my rims so i did a search and found this template showing the overall width of the 6 piston calipers. It is a pdf file but tells you how much space you must have to clear the calipers.
http://www.kore3.com/downloads/fitme...es/DOC0019.pdf
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-19-2008, 03:09 AM   #17
68 short step
baer.com doesnt give a phone number or a option to buy direct from them via internet.....how would i get ahold of "bill"?
Old 07-14-2009, 02:34 AM   #18
ajgriffin
ajgriffin's Avatar
Any update from the "well known manufacturer"? (I have no clue who that is BTW)
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
Old 07-14-2009, 08:14 AM   #19
SCOTI
SCOTI's Avatar
You have PM.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
