03-13-2008, 12:27 PM | #1 |
looking for a th400 to 205 adapter
title says it all either I buy an adapter or I will sell my tranny and xfer bought the truck with a 400 and 203 broke the adapter off flush with the transfer and cracked the transfer now I have a 205 but no adapter long story short swerved to miss a dog hit a big azz rock in a ditch smack dab on the xfer bottom and the rest is history literally lmk what ya got and what ya want for it thanks Mike
hav'n fun be'n me |
03-13-2008, 03:01 PM | #2 |
Re: looking for a th400 to 205 adapter
You should post this in the 4x4 section.
Is the adapter a figure 8 or the round 6.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-13-2008, 04:47 PM | #3 |
that will defiately be hard to find
03-13-2008, 07:58 PM | #4 |
I have a K-case Th350 to a 203, are the 400's different? Also have 350 to 205
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-13-2008 at 09:38 PM. |
03-13-2008, 08:17 PM | #5 |
I have one $150. LMK
03-14-2008, 03:34 AM | #6 |
Be sure you get the "short" adapter (it's really rare, as in never seen a stock one, can buy one from Stak4x4 for the round 6 bolt pattern NP205.
A 203 used the shortest output shaft in the Th400. NP 205 can use two separate length Th400 output shafts, one that will work with the 203 Th400 and one that won't (although I've never seen a stock one, I've read about 'em). The two on the left are t-case input shafts used with Th400's. A 205 typically used the second one from the left where the 203 used the first one on the left. You can switch inputs amongst the 205s. A TH350/205 combo would be 10 spline male or 27 spline female input and not mate up to his transmission, some were mail input with a sleeve (see the ones on the right in that picture). Photo grabbed from another thread... Last edited by FormerMember; 03-14-2008 at 07:06 AM. |
03-14-2008, 07:01 AM | #7 |
wow I had no idea how involved this was will have to actually pull and inspect the parts to make sure of what I need. thanks to all who have replied Mike
70rs/ss Mike I will be taking that if I am able to use it will let you know asap muddyyole 69 aka Mike
hav'n fun be'n me Last edited by muddyole 69; 03-14-2008 at 07:03 AM. Reason: added stuff |
03-14-2008, 07:11 AM | #8 | |
The 205 you have, what bolt pattern is it? 8 holes or 6 holes? I have several output shafts (for the cost of shipping) I could send you, depending on the thickness of Mike's adapter and the bolt pattern on your 205. |
03-14-2008, 12:02 PM | #9 |
72 chevy
The turbo 400 205 case has a bigger bearing for the input shaft so if you use either a 10 or 27 spline case it will have to be bored to the bigger bearing size to fit the 32 spline input shaft.
The 10 spline 205 is for the stick shift trans. The 27 spline 205 is turbo 350 both use a sleeve. The turbo 400 has a 32 spline male out put shaft and the 205 will have a 32 spline female input shaft. I didn't know thy made a adapter and thats cool to find out it will save me some headache's down the road too. Hope this helps. Ed |
03-14-2008, 05:55 PM | #10 | |
03-15-2008, 12:36 AM | #11 |
You should try to find a th400/205 set-up out of a big block one ton, early to mid 80s i believe. having the whole set-up would prolly be better than piecing, but that's just me.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
