Old 03-14-2008, 02:35 AM   #1
Lafayette 68K20
WANTED: Stock Steering Column
NO LONGER NEEDED - THANK YOU. I'm looking for a stock steering column from a manual floor shift transmission and stock power steering 67-72 truck. Tilt or no tilt is fine. Do not need the steering wheel.
Richard
1968 Chevrolet K20 CST 327 (being restored)
2005 Toyota Camry LE V6 (bought for mom to drive)
2007 Toyota Camry Hybrid (daily driver)
2009 Toyota Sienna (wife's ride)
Last edited by Lafayette 68K20; 03-21-2008 at 02:17 AM. Reason: Stock steering column is adjustable.
Lafayette 68K20 is offline   Reply With Quote
Old 03-14-2008, 02:45 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: WANTED: Stock Steering Column
lafayette,
I'll PM my Number
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-14-2008, 07:05 PM   #3
Ridgeback
I have several of these in black ($65 plus shipping) and dark green ($75 plus shipping). If you are interested post your email address and I will send you some pictures.
Ridgeback is offline   Reply With Quote
Old 03-14-2008, 11:15 PM   #4
Lafayette 68K20
Thanks Ridgeback. Looking for Black.
Richard
Last edited by Lafayette 68K20; 03-15-2008 at 07:24 PM. Reason: Removed my email address
Old 03-15-2008, 08:37 AM   #5
Ridgeback
Lafayette 68K20
I had troble emailing the pictures so I posted them here instead.
General condition is good and includes turn signal switch, wiring and the lower shaft although the lower shafts are not shown in the pictures. I usually remove the lower shaft to make the shipping box shorter. The steering wheels are scrap and not worth shipping. If you are interested post your Zip code and I will get a shipping estimate. Thanks.
Ridgeback
Old 03-15-2008, 07:23 PM   #6
Lafayette 68K20
Ridgeback - thanks. Just to confirm, the black one came off a truck that had a factory power steering box - not a manual steering box - correct?
Richard
Old 03-15-2008, 09:09 PM   #7
Ridgeback
Lafayette 68K20
As I recall all the columns were from trucks with PS. If there is a difference from a manual steering column let me know what to check and I will let you know. Thanks.
Old 03-16-2008, 11:50 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
Lafayette 68K20
Can you email me with pictures and info on the columns. I live in VA and could pick up if possible. Thanks!
VA72C10 is offline   Reply With Quote
Old 03-16-2008, 08:49 PM   #9
Ridgeback
VA72C10:
Several pictures posted above.
If you post your email address I will send you some additional pictures. Thanks.
Old 03-16-2008, 10:55 PM   #10
RicksTrucks
RicksTrucks's Avatar
Lafayette 68K20
Don't believe there is a difference.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 03-17-2008, 04:30 PM   #11
tommypic
tommypic's Avatar
found one here http://cgi.ebay.com/ebaymotors/1967-...em330219225268
tommypic is offline   Reply With Quote
Old 03-18-2008, 09:09 AM   #12
Ridgeback
VA72C10:
I will email you.
Does anyone know if PS colums are different than manual steering columns? If so, what is the difference? Thanks.
Old 03-21-2008, 02:15 AM   #13
Lafayette 68K20
Hi Ridgeback:
My apologies. It appears that the factory steering column I have will work just fine. Turns out the length of the d-shaft on the column is adjustable, and can be shortened to work with a power steering box.
I won't be needing a column from you. Thanks so much for offering, and hope to do business with you in the future.
Richard
