Old 03-14-2008, 05:36 AM   #1
jkade
jkade's Avatar
Going to a bbc in my K10 and have questions
Bought a gm crate 454 to go in my 86 k10 that is complete motor with everything on it. I believe the engine mounts will work back and I will need a new flywheel for the 465 and a new clutch while I am there. I guess I should put in a bigger radiator also. Can you think of anything else? Figured I would run some elcheapo headders from summit.
jkade is offline   Reply With Quote
Old 03-14-2008, 05:44 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Going to a bbc in my K10 and have questions
You'll need the matching upper radiator mount/cover, shroud and cushions if you are upgrading the radiator.
bigblock73 is offline   Reply With Quote
Old 03-14-2008, 05:51 AM   #3
jkade
jkade's Avatar
Could I use the radiator setup from a k30 with a 6.2?
Old 03-14-2008, 05:13 PM   #4
slug
slug's Avatar
i think you will have to use a 1 piece fan shroud for sure.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
