Old 03-14-2008, 05:19 PM   #1
engrdean
Quick Intake Bolt Question
It has been a ridiculously long time since I took my intake off my truck due to a broken bolt when attempting to remove the water pump. I got everything polished and painted and wanted to order a new set of ARP bolts to put it back on. I could have swore that there was more than one length of bolt used for the intake whenever I took it off. Am I crazy? From searching the forums I see that the factory length is 1 1/4" and looking at Summit's website, all the bolts look to be one length. If someone could just confirm that I don't need anything special depending on whether I have AC or some other options, I would really appreciate it.
engrdean is offline   Reply With Quote
Old 03-14-2008, 05:50 PM   #2
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
Re: Quick Intake Bolt Question
yep, all the same length.
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-14-2008, 05:55 PM   #3
engrdean
Thanks for the quick reply.
Old 03-14-2008, 06:02 PM   #4
72swb_327stroker_?
knuckle buster..
no prob!
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 03-14-2008, 06:37 PM   #5
Huck
Huck's Avatar
Use bolt thread sealer or you may have coolent leak up the bolt hole onto the intake.
Huck is offline   Reply With Quote
Old 03-15-2008, 03:55 PM   #6
Blazer1970
Blazer1970's Avatar
The original A/C compressor bracket bolted to the two front intake bolts on the passenger side, so longer bolts were used in that spot on trucks with air.
Blazer1970 is offline   Reply With Quote
