Active Member
![]() Join Date: Jun 2002
Power steering box
Just finished putting disc brakes from an 81 truck. I want to install the power steering box but don't have a pump (donor truck has Cadillac eng). Would you damage the steering box if you don't have fluid going to it? Could you just fill it and run a hose from pressure side to return side?
I have been working on this for several years now and it's one thing for the wife to complain about projects in the yard but I'm getting tired of seeing some of them.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Power steering box
I'm sure its not good for it. When I did mine I didnt have all the pulleys worked out so I just duct taped over the fluid holes and drove it.A couple of months later it all hooked up and worked fine.
Active Member
Thanks for the advice. One other question did you have a problem with the power steering box hitting the bumper brace?
You can get a brace from a P.S. donor or just grind out a notch in the old one.
its all about the +6 inches
I would route the lines like you said, I don't think it'll damage anything, i've seen people do it for years on other makes of cars (one dodge, and a ford).
Active Member
Thanks all. Still didn't get it finished but almost. Had 4 yr old grandson "helping" me keep all the nuts and bolt in the same place. Plus he learned how to use the wire cutters.
