One of these days.......
disk break question
Is it possible to use disk break parts from a 99 up chevy to convert a 68 over and keep it 6 lug.
Questionable
Re: disk break question
I don't know the specifics on this, but I've read that the center hub or center of the wheel opening on the newer 6-lugs and the older 6-lugs are different. I don't even know that this is of consequence to you, just tossing it out there.
I can't really help with the question, but here's a bump to the top anyways.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Hellasick
![]() Join Date: Jul 2006
Don't know that '99 and up will work, but here is a thread in FAQs on using '88-'92 light duty 3/4 ton set up.
easydiskbrakeswap
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
Insert Title Here
disk break... that sounds painful
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
