03-14-2008, 07:00 PM | #1 |
'65 C10 Wiring Problems
'65 Chevy C10. The last owner pulled out the 292 six and did a poor job dropping in a 350 sb. Bought it for $500 about 3 years ago. Its sitting in the garage, as a work in progress, and trying to do all the necessary repairs to get it on the road.
The battery drains faster than the starter motor can turn over. With a fully charged battery, where could it be draining from so quickly? Thanks for any advice. Last edited by Reyals Bemus; 03-14-2008 at 07:01 PM. |
03-14-2008, 07:41 PM | #2 |
Re: '65 C10 Wiring Problems
Radio always comes to mind, but this is probably one that will take time and trial and error.
Hookup a 12V bulb inline on the battery positive, it will glow when there is a draw. Just start disconnecting wires (one at a time) until the bulb goes out. <edit> you can pull fuses to narrow this down quicker, it will require that you have a helper though (either to watch the bulb or pull/insert the fuses) </edit> Last edited by kevindtimm; 03-14-2008 at 07:42 PM. Reason: speedup hint |
03-14-2008, 08:55 PM | #3 |
Cantankerous Geezer
My first check would be to disconnect the alternator wire. A bad alternator can drain the battery like you describe.
Fred There is no such thing as too much cam...just not enough engine. |
