Old 10-27-2002, 08:23 PM   #1
Southpa
Southpa's Avatar
Good news and bad
Just finished a coolant flush and replacement. Replaced the 180 thermostat w/ a 192. I also installed a mechanical temp gauge.
Then I took it for a spin to the store and back. The temp didn't go above 190 and hovered at 180 while driving. So all in all I managed to cool things down by a good 15 degrees on average.
One thing tho, I noticed the lower part of the rad was cold when I got back. I guess some of the tubes are plugged. I'm assuming this isn't normal. The rad is only about 3 yrs. old but I guess it needs some maintenance. Is this normal or is my assumption about the rad right?
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 10-27-2002, 08:32 PM   #2
crazy longhorn
Fabricate till you "puke"
The lower part of the rad should be cooler than the top,Im also guessin the weather is gettin a little cooler up in your neck of the woods. if it doesnt overheat, I wouldnt sweat it. good luck.....crazy AL
crazy longhorn is offline   Reply With Quote
Old 10-27-2002, 11:00 PM   #3
Hooter
My other Love
Hooter's Avatar
If it inst overheating or leaking there shouldnt be a problem and the rad should be kinda cooler on the bottom anyways. That just shows you that its doing it job
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-27-2002, 11:34 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Is that where your tranny cooler lines are at?
