Old 03-15-2008, 04:43 AM   #1
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Mission: Impossible?
O.k. I've been wracking my melon for a couple weeks now on how to get the G.D. Pulley off the PS Pump shown below. I wanna blast and paint it on both sides before I install my J.Y. serp.system! I've tried gear pullers, drift punches, and even retained the services of a deep-bayou voodoo witch (nevermind that- she was hired to get something else off !)
Anyhoo, I really need to get my serp.system on- so if anybody has any nuggets of wisdom- please share!
Name:  PS Pulley.JPG
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 03-15-2008, 04:54 AM   #2
bglad420
bglad420's Avatar
Re: Mission: Impossible?
It's threaded. I beleive...
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50.
bglad420 is offline   Reply With Quote
Old 03-15-2008, 04:57 AM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
That looks like its pressed on. There is a tool to remove it. It hooks in that grove on the end of the pulley and pushes on the shaft.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-15-2008, 05:02 AM   #4
68Stepbed
68Stepbed's Avatar
Did you try a dedicated ps pulley removal tool or just a gear/pulley puller? I believe that is what kelsfine69 is referring to.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-15-2008, 05:15 AM   #5
GruntyPants
GruntyPants's Avatar
There is a specific tool to remove those GM style power steering pulleys. You can get one at about any parts store. Don't try using a 3 jaw puller, you'll ruin the pulley... ask me how I know ;-)
Shawn
Shawn
'67 Short Step
'70 Short Wide
GruntyPants is offline   Reply With Quote
Old 03-15-2008, 05:24 AM   #6
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Shawn
Just to clarify what everyone is saying- its a rental tool available at auto zone & such. While you are waiting spray it with a little PB Blaster.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-15-2008, 06:27 AM   #7
sjarrett71
sjarrett71's Avatar
Yes, what Sport/truck said. If you take it to a parts store they will probably even help you take it off. I did a bunch when I worked at AZ.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 03-15-2008, 06:49 AM   #8
BurnoutNova
BurnoutNova's Avatar
Shawn
almost all p/s pump pulleys are held on that way, unless they bolt on to a flange
BurnoutNova is offline   Reply With Quote
Old 03-15-2008, 06:57 AM   #9
nuke1
nuke1's Avatar
i got that the tool from snap-on to do that at work and yes it is a dedicated tool just for removing those, otherwise you just end up ruining them.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-15-2008, 07:31 AM   #10
cdowns
cdowns's Avatar
the puller is so cheap ,i paid less than $10 that it's not worth getting as a "free" rental with the price of gas going back and forth to the auto parts store. buy the tool you've got for life with only one trip to the store
Old 03-15-2008, 08:26 AM   #11
HoupPhotography
YES!! you need a specific tool to remove it... DO NOT rent the checker or auto zone tool, they don't work. If you don't have the tool, take the pump to a machine shop and have them pull it off, as mentioned by nuke, if you don't use the specific tool it will reuin the pulley, you will break the flange on the end of the pulley. I made the above mistake on my Jeep motor and reuined the pulley.
BTW - it does not screw on!
HoupPhotography is offline   Reply With Quote
Old 03-15-2008, 07:38 PM   #12
Dingfodgy
Dingfodgy's Avatar
Ok- It looks like I'll need to have it pressed back on once I get the pulley back from the powder coater...I just hope the shop doesn't eff up the pulley puttin' it back on!
Old 03-15-2008, 09:01 PM   #13
dznucks
dznucks's Avatar
i have taken mine to advanced autoparts and they will pull it off for you.
dznucks is offline   Reply With Quote
Old 03-16-2008, 03:36 AM   #14
svgould
Active Member
svgould's Avatar
The puller kit I bought came with a bolt to press the pulley back on. Shouldn't have to use a press.
Shane
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 03-16-2008, 09:03 AM   #15
69long"n"low
69long"n"low's Avatar
The kit we have at my shop removes and installs it we got it from snap on and it was only like $60CND
69long"n"low is offline   Reply With Quote
Old 03-16-2008, 09:08 AM   #16
67_C-30
I have a radical idea!
67_C-30's Avatar
Shane
I don't know about everywhere, but at Advanace Auto Parts here they will do for you for free with the tool mentioned above and an electric impact wrench. The same tool removes and replaces it as said above also.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-18-2008, 01:18 PM   #17
Machinist1972
Machinist1972's Avatar
Try using a tie rod puller or something similar to this, you want a puller that will have tangs to fit in the groove. When you want to install the pulley use a heavy grade ready rod and thread it into the shaft on the pump, once it is threaded in put the pulley on, followed by a thick washer and nut. You can use vise grips or something to hold the ready rod now tighten the nut this will press the pulley back on. Here are some pics.
Machinist1972 is offline   Reply With Quote
Old 03-18-2008, 03:09 PM   #18
brak
brak's Avatar
Don't waste your time trying to find find a shortcut. The correct tool is cheap, and definately worth having around.
I've used mine a million times, definately worth the $30 i spent
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
