Old 03-15-2008, 04:59 AM   #1
blazerguy71
blazerguy71's Avatar
gas tanks
guys I need some help please. my blazer needs a new gas tank and i'm having problems deciding which to get which do ya'll think is the better choice the poly (plastic) or a steel tank now keep in mind the reason my tank is junk is because of rust it's been sitting since 1998 my wife says plastic but i am having a hard time deciding could use some help let me know what ya think.
Adam
blazerguy71 is offline   Reply With Quote
Old 03-15-2008, 04:30 PM   #2
vtblazer
vtblazer's Avatar
Re: gas tanks
What are your pros and cons concerning the two?
Metal = rust sure but hey, it lasted almost 35 years - right?
Poly = ? What's your concern with the plastic?
vtblazer is offline   Reply With Quote
Old 03-15-2008, 04:40 PM   #3
tommypic
tommypic's Avatar
Re: gas tanks
check out this site http://www.speedyautoparts.com/find/...EPICKUP67.html
going to get my tank for swap from them
tommypic is offline   Reply With Quote
Old 03-15-2008, 04:40 PM   #4
49m
49m's Avatar
Re: gas tanks
I just bought a poly tank for my truck
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 03-15-2008, 11:42 PM   #5
krc400
Re: gas tanks
Just installed Poly on my 72. Works great, had to get a longer hose from filler neck.
krc400 is offline   Reply With Quote
Old 03-16-2008, 12:39 AM   #6
CJ5 Convert
CJ5 Convert's Avatar
Re: gas tanks
Call TIm Christian @ Christians Classics 877-654-2287. I just bought a new kit from him last week and they were a pleasure to deal with mine is metal I'll let you know how it fits. _jason
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
CJ5 Convert is offline   Reply With Quote
Old 03-16-2008, 06:10 AM   #7
blazerguy71
Re: gas tanks
thanks but they didnt have one for my year!
Old 03-16-2008, 11:03 PM   #8
drunkbus
New Member
drunkbus's Avatar
Re: gas tanks
Does anybody know if ethenol will effect the poly tanks at all? Here in Oregon starting in April our gas will have 15% ethenol in it and I know my dad had to change out all the fuel lines in his boat because of this.
drunkbus is offline   Reply With Quote
Old 03-17-2008, 07:51 PM   #9
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Re: gas tanks
My only question would be how the poly tanks hold up in our trucks in super cold weather. I know the mounting method works for steel, and I dont know if its a big deal for poly.
My original is still in my K-5, however it has been repaired a few times. For me it would boil down to fixability, price and warranty. Steel I can fix, poly I cannot. So "fixability" is a factor for me.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 03-19-2008, 05:57 AM   #10
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Re: gas tanks
Hey Adam, since I haven't needed a new tank, I stayed out of the way of the more knowledgable folks here, but no one mentioned an older thread that I don't have a link for. I do remember pieces of it concerning installation of an aftermarket steel tank. It seems the filler flange isn't correct, but a radiator shop can remove the new one and solder on the factory one from your old tank on at a reasonable price. I would recommend Dakota Radiator as a board member, Bryan (67 cst swb), works there if you decide to go steel and the flange needs to be swapped.
Poly tanks should work just fine with any amount of ethanol. Dirt track Late Model stock cars and Sprint cars run 100% Methanol in poly tanks with no problems as far as a chemical reaction to the plastic. Methanol is a lot "stronger" than ethanol.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 03-21-2008, 04:30 AM   #11
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
Re: gas tanks
i am getting ready to pull my poly tank off my 72 blazer, let me know if it will work for your truck. also for the other response, ethynol will only effect your fuel lines and maybe carb, but dont worry about your poly gas tank it will be fine
72blazer_mud_bogger is offline   Reply With Quote
Old 03-21-2008, 07:38 PM   #12
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: gas tanks
I know I have read from a post or two in the main section that some people have had issues with the plastic tanks sagging. Those posts were probably 3-4 years old and I don't recall seeing anything on that issue recently.
Here is the thread concerning the steel tank fitment issues.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-21-2008, 11:22 PM   #13
krc400
Re: gas tanks
There is a thread on an aftermarket steel tank where the filler neck is not correct. The poly I installed was the same way.
Old 03-25-2008, 12:23 AM   #14
CJ5 Convert
Re: gas tanks
Yeah I just started putting in my repop tank and the neck is in the worng place. But I guess when life gives you lemons ... From all the treads I could find you have to make the same mods the truck guys are to make having to make. To get around the rear bed cross member once I get mine fixed I'll shot some pics. -J
- Jason
