03-15-2008, 06:11 AM | #1 |
Wont Start?
67 327 holley 4barrel with an HEI ignition. She was running fine then sat for a couple months got it to sputter once now nothing. Its getting gas and Ive checked for spark and have that as well. It just cranks and cranks but nothing. Could I have a bad module in my HEI and still be getting spark maybe it screwed the timing all up dont know Im lost now.
03-15-2008, 06:41 AM | #2 |
Re: Wont Start?
My camaro did this one time. It ran just fine, I put a water pump on it, and then it wouldn't run. I pulled out the distributer and dropped it back in and it started and ran just fine. When it would get warm it would die and act like vapor lock. I pulled out the fancy MSD module and put a stock one in and it ran just fine. It seems od it is sparking but not starting. When mine did this I was told to check that the gears on the distrubuter were good and that the timing chain was tight and didn't jump.
03-15-2008, 11:40 AM | #3 |
Re: Wont Start?
check for spark on more than one cylinder, also if the spark is weak and yellowish in color, it might not be creating a spark under compression.
its possible the module could be bad, ive heard ignition modules do alot of crazy/ intermittent stuf when there going bad. |
03-15-2008, 09:06 PM | #4 |
Re: Wont Start?
I had a similar problem and it traced back to the carb. Cleaned it out and fired right up.
71 C-20 Custom Camper California Truck |
03-15-2008, 09:52 PM | #5 |
Re: Wont Start?
I agree with all that was siad above...you check the timing?
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
03-15-2008, 10:31 PM | #6 |
Size Matters
Re: Wont Start?
How expensive is a module?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
03-16-2008, 06:31 AM | #7 |
Re: Wont Start?
Rebuilt and cleaned the carb with a kit yesterday had the module tested today it checked out fine replaced the capacitor module since it looked shady. I checked and have spark at the cylinders and fuel going in the manifold.... Im totally stumped and ready to throw in a stick of dynamite.
03-16-2008, 08:42 AM | #8 |
72 Chevelle Club
Re: Wont Start?
Have you checked to see that the timing is correct ? You may have a timing chain issue . bring it up on #1 and check it if you haven't already . That's all I can think of right now you got me stumped also . hope this helps . Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
03-17-2008, 02:19 AM | #9 |
Size Matters
Re: Wont Start?
That "sputtered once" thing is buggin me...could have jumped time as some have already mentioned. I would take a look at the timing but I would also check the plugs if you havn't already...fouled maybe? How old is the gas in the tank?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! Last edited by Longhorn321; 03-17-2008 at 02:20 AM. |
03-17-2008, 03:22 AM | #10 |
Between Trucks...
Re: Wont Start?
Gas might have gone bad...
Beat it to fit, Paint it to match... |
