Old 03-15-2008, 09:20 AM   #1
dan42
dan42's Avatar
gas tank grommet question...
Can you replace the grommet without pulling the tank out? Stupid question, maybe, but I've never done it before and don't want to cut the old one out before I realize what's involved.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-15-2008, 09:53 AM   #2
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Re: gas tank grommet question...
Yes, but you have to be very careful. Cut it out from the backside with a razor knife. Try warming the new gromet up under a spotlight or something to make it softer. I've replaced them without removing them, so i know it's possible
Justin
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 03-15-2008, 01:55 PM   #3
Trent_McAllister
Interesting...That happens to be about exactly where I am at..even looks like your truck was the same yellow as mine. Let me know how it works for you, but since I have the seat out, I will probably pull the tank anyhow.
My Truck:
1968 C-20 Custom Camper
Trent_McAllister is offline   Reply With Quote
Old 03-15-2008, 05:22 PM   #4
Jim_PA
Is this straightforward when the tank is out? Or is there a trick to doing it then too?
Getting ready to upgrade fuel system, and might as well do a new gromet while swapping tanks.
Jim_PA is offline   Reply With Quote
Old 03-15-2008, 06:43 PM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
Cut it out and smear dish liquid to the new one and slide it on. Easy! No need to pull the tank for a 2 minute job.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 03-15-2008, 06:45 PM   #6
dan42
dan42's Avatar
I'll let you know how it turns out - I'm gonna do it this weekend.
Philippians 4: 6-7
Old 03-15-2008, 07:05 PM   #7
BurnoutNova
BurnoutNova's Avatar
yep, when the tanks out its pretty easy, just slide the filler neck up through the hole.
BurnoutNova is offline   Reply With Quote
Old 03-15-2008, 07:56 PM   #8
Jim_PA
Old 03-17-2008, 06:48 AM   #9
dan42
dan42's Avatar
I looked at it and I chickened out - The grommet is rock hard and hard to get to, and I have to take my seat out again anyways, so I'll wait.
Philippians 4: 6-7
Old 03-17-2008, 08:32 AM   #10
prg machine
prg machine's Avatar
Have no fear. Cut that old turd outa there and replace it with a new one. Use Gibbs www.gibbsbrandlubricant.com to lube the rubber and it will jump in that hole!!!
Been there done that!!!!!
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 03-17-2008, 08:36 AM   #11
BAGGERSOCAL
Active Member
its a easy install just replaced mine a few months back
BAGGERSOCAL is offline   Reply With Quote
Old 03-17-2008, 09:03 AM   #12
dan42
dan42's Avatar
Well, now you got me thinking - maybe I'l try tomorrow. If I can't get it I can always pull the tank, I have to pull the seat anyways. I'll let you know how it turns out.
Philippians 4: 6-7
Old 03-17-2008, 10:51 AM   #13
prg machine
Only one chicken around this forum............and that be me!!!
Aerostotle be my name!!!!
383 .040 over
