Old 03-15-2008, 10:03 PM   #1
TotalChevy1
TotalChevy1's Avatar
How to test if a tach is good
I have a 7k rpm tack that looks like the board is fried, is there any way of testing it without hooking it up? My truck is disasembled so, hard wiring it to a engine is not an option. Would an ohm meter work or ?
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 03-16-2008, 12:34 AM   #2
TotalChevy1
Re: How to test if a tach is good
ttt
Old 03-16-2008, 05:22 AM   #3
TotalChevy1
ttt
Old 03-16-2008, 01:41 PM   #4
JimKshortstep4x4
I don't know of an easy way to test a tach. The ohm meter will check continuity but since the tach receives electrical "impulses" from the distributor, you would need a piece of equipment that generates these "impulses".
Do you have another truck or car that you could temporarily hook the tach up to?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
