Old 03-16-2008, 02:14 AM   #1
drivethechevy
drivethechevy's Avatar
engine questions
im out of comission due to a surgery for a while and i have decided to build up my 350 out of my 68 gmc and build myself a nice work truck out it for me and my dd to use and i was wondering what the outcome of putting some 283 heads on the 350 would be or even if the heads would be able to beput on the 350
so if anyone knows if 283 haeds can bolt nto a 350 and what effects it would have on the engines compession and troque and hp i would like to know
thanks
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 03-16-2008, 02:42 AM   #2
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: engine questions
All SBC heads should be interchangeable until you get to 1986 or so.....except the Small Block 400- those have siamesed center bores so there's water jacket issues. The source of the heads really doesn't determine the compression ratio and the like. It all has to do with Combustion Chamber volume, deck height, piston profile, rod length and crank stroke. I don't have the specific characteristics of all the various SBC heads memorized- so you'd hafta check valve size, C.C. volume and possibly intake runner volume for somebody on here to make an educated assesment of what the results might be.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 03-16-2008, 08:45 AM   #3
Ole Blue 68
Ole Blue 68's Avatar
Dingfodgy's got some good info there. My gut is saying it ain't going to be a good combo.
Ole Blue 68 is offline   Reply With Quote
