Old 03-16-2008, 04:49 AM   #1
69heavychevy
69heavychevy's Avatar
edelbrock performer rpm???
i was cleaning up the manifold before it went back on the truck. i started picking at what i thought were clogged coolant passages on the rear. well it turns out the are actually blocked off. i found when i started drilling and hit a aluminum wall. are they supposed to be like this?
69heavychevy is offline   Reply With Quote
Old 03-16-2008, 05:01 AM   #2
wibilly
wibilly's Avatar
Re: edelbrock performer rpm???
there are no coolant passages on the back of the manifold
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-16-2008, 05:13 AM   #3
69heavychevy
oh, i just figured there was since there is some on the heads
Old 03-16-2008, 05:18 AM   #4
berencam
berencam's Avatar
yup mines the same way.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 03-16-2008, 05:28 AM   #5
71big block
1971 GMC 3/4 ton, 572 CID
71big block's Avatar
The heads have the holes on each end so that they can be used on either sidem intakes only have the cooling passages on the front
71 GMC 3/4 572 CID,
1988 GMC 1/2
2006 Saturn Vue
"We always have parts left over on a job this size"
71big block is offline   Reply With Quote
