Old 03-16-2008, 06:00 AM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
OK ole WISE ONES, QUESTION!!!
I've never had this happen before BUT I cannot get the 205 knob off my shifter in the truck. I've used the rubber mit you use in the kitchen to take off lids off jars, I used a strap wrench, I PB Blastered it still it won't budge. I've got a blister from trying to turn it so many time with my hand. I don't want to tear it up because its in good shape. ANY IDEAS??? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-16-2008, 06:12 AM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: OK ole WISE ONES, QUESTION!!!
You use a rubber mit to loosen jar lids!!!
You might try tapping it around the edges with a rubber mallet..other than that some cocentrated heat just below the threads on the shaft of the shifter. Good luck, I've never had one that tight before.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-16-2008, 06:17 AM   #3
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
What a big girl you are seriously try squirting some WD40 and leaving it to seap in, and beleave it or not try tightening to break the seal that has obviously developed...it does work.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 03-16-2008, 06:18 AM   #4
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
What about using a blow dryer or heat gun to heat the knob. It might take a while to get it heated all the way through. Once it's heated good spray PB Blaster on the threaded part and let it cool. While it's still hot/warm, take a brass hammer or something that will not damage the metal and tap on the metal shift handle. Just my .02. Good luck!
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 03-16-2008, 06:35 AM   #5
krazy_texan
krazy_texan's Avatar
i say wrap it up real good in a rag and then put a pipe wrench on it
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 03-16-2008, 06:35 AM   #6
prg machine
prg machine's Avatar
www.gibbsbrandlubricant.com
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
Last edited by prg machine; 03-16-2008 at 07:24 AM. Reason: wrong reference to product web page
prg machine is offline   Reply With Quote
Old 03-16-2008, 06:38 AM   #7
odog
odog's Avatar
I agree, Try tightening it, A seal does develope and it sounds wierd, but tightening it just a touch breaks that seal and it should then turn off.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 03-16-2008, 06:53 AM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
There should be a lock nut on the bottom side of the knob that you have to turn clockwise first before trying to loosen the knob. If you have done this, then hot air gun would be your next option. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-16-2008, 06:54 AM   #9
This is a trap,right?All the stuff you`ve undone and you`re seeking our advise how to get a knob off?
Old 03-16-2008, 07:17 AM   #10
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
TIM GOT YA ON THAT ONE! WES HAS GOT ANSWER.
Daren
04 Chevy Extend cab 2500HD 6.0 Liter 4x4
71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY
Rip El Jay
RIP BOBBO'S MOM
88JRFAN is offline   Reply With Quote
Old 03-16-2008, 07:28 AM   #11
prg machine
Originally Posted by prg machine View Post
This stuff is the best penetrant we have ever used..............it is used on overhaul and maintenance of jet engines and helicopter components subjected to the elements and high heat... it never fails to get stuff "Unstuck"!!!
383 .040 over
Old 03-16-2008, 07:44 AM   #12
chipflyer
chipflyer's Avatar
Randy,
I know you already have the jam nut loose, I am guessing that if it won't budge with the strap wrench, its because someone has used lock tight on it. If that is the case (and they used red) you won't get it loose unless its heated no matter how much or what kind of penetrating oil you squirt on it. . You could do 1 of 2 things, make a heat shield from a piece of tin to protect the knob with a 1/2 slot cut in it and use your torch to carefully warm the shifter just below the knob. Heat rises, that may work.
Option 2, since you want to remove the knob to install the carpet, remove the shift handle from underneath, that will make the carpet install pretty easy and you wont damage that nice knob.
Just a couple ideas
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 03-16-2008, 08:29 AM   #13
prg machine
Heat has got to work eventualy................then squirt it good..............and good luck...................We have removed stuck exhaust bolts this way..............certainly that knob should come loose!!!
383 .040 over
Old 03-16-2008, 08:30 AM   #14
prg machine
The rooster knows!
383 .040 over
Old 03-16-2008, 08:50 AM   #15
teeitup
teeitup's Avatar
Some of you guys are to funny!!! I've tried tightening it, I've had the lock nut loose from the start, I've tried all my rubber stuff. I tried PBBLASTER, I guess I'll have to try heat. I'm changing it to a chrome shifter, and I have the black shifter sold without the knob. Thanks for the ideas guys. I'll work on it Sunday hopefully. Randy
1980 chevy swb 4x4
Old 03-16-2008, 09:59 AM   #16
dan42
dan42's Avatar
It's bizarre how the littlest things can trip you up when you're doing stuff to your truck. They are potentially the most frustrating at times. But that's part of the reason we work on them, I guess, for the satisfaction of getting past those things succesfully.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-16-2008, 10:10 AM   #17
nyncompute
nyncompute's Avatar
Randy, when you're done forcing it tightening it, gripping it greasing it and burning it..... for a change I don't want to buy it!
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 03-16-2008, 10:47 AM   #18
Ridgeback
I bought a 465/205 combination several weeks ago from a fellow who had parted a 71 K20. He said he got tired of the shifter knobs "squirming around" all the time so a year or two before he stopped running the truck he epoxied the threads and solved the problem. Could be the PO of your transfer case did the same.
Ridgeback is offline   Reply With Quote
Old 03-16-2008, 08:56 PM   #19
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
If it's not going to come off without boogering it up... the knob is valuable... the shifter isn't... I'd cut the shifter off as close to the knob as possible. Weld a nut to the end of the stub, let it cool just a bit, then hit it with a 3/8" impact & it should spin out. If you catch it at just the right time when the heat has soaked into the threads, it will help break the rust &/ or locktite loose.
Question- I have an '80 chrome 205 shifter I want to put my '72 knob on. I'm thinking the threaded stub is bigger on the chrome shifter?
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 03-16-2008, 09:22 PM   #20
lolife99
67-72 parts collector,…
lolife99's Avatar
Someone probably used loctite on it. The "high strength" stuff require a torch or heat to remove. Always use the "medium strength" on something you might want to take apart.
Keith
Convert to disc brakes.
