03-16-2008, 06:10 AM | #1 |
headlight troubles
k so last night i had 2 move the truck out of the garage last night and wen i turned on the headlights, only the passenger light came on. wen i turn on the high beams they both work properly. im guessing its just a loos connection but i didn't really look yet. if it is a loose connection would it be at the switch or the light socket. thanks
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
03-16-2008, 06:50 AM | #2 |
Size Matters
Re: headlight troubles
Well, it certainly could be a loose connection but aren't those dual element sealed beam lights? What if the low beam element is just burned out? Check for power at the low beam terminal.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
03-16-2008, 07:00 AM | #3 |
Yep, I was thinking the same thing, the low beam could just be burned out.
03-16-2008, 07:15 AM | #4 |
its all about the +6 inches
burned out headlamp
03-16-2008, 08:07 AM | #5 |
i always like to replace really old headlights in pairs to get better more evaen lighting//take the time to clean the contacts real good and put dielectric grease on them
03-16-2008, 07:29 PM | #6 | |
Had same thing happen to me yesterday...checking things over getting ready for spring (if the snow will ever leave...not) and turned the lights on and no head lights...Hummmm Flipped the high beams on and all 4 worked...back to low and left side is now on but no right. Wiggled the connections on/off at the lights and all is good now...just a bad connection there. So suspect you have the same deal going on |
03-17-2008, 01:54 AM | #7 |
Size Matters
Sometimes the element is wigglin around inside and when you bump it, it will start working...bump it again and it might stop working again.
