Old 03-16-2008, 06:54 PM   #1
yenko427
yenko427's Avatar
Oil line to gauge
Can someone tell me what size copper line goes to the cluster and size of the nut that is on the cluster mine is gone.
yenko427 is offline   Reply With Quote
Old 03-16-2008, 08:33 PM   #2
nyncompute
nyncompute's Avatar
Re: Oil line to gauge
If you want to stay original, I believe it is an 1/8 line although I can't say what size fittings it uses. I do recall I couldn't find the pieces parts in the usual places (lowes Auto Zone etc.) .Kinda unusual setup I think . I wound up using a used line from another truck due to the hassle factor. I now they repop them these days. Thats what I'd do.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 03-16-2008, 09:47 PM   #3
prg machine
prg machine's Avatar
go to a reputable auto parts store and buy one of the plastic tube oil line kits. they have all of the right stuff.
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 03-17-2008, 05:39 AM   #4
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
The oil line is 1/8" and the nut is a male thread with the brass ferrule. Most oil line kits have the female thread nut. Not sure of the size of the nut. I suppose if you ask for the 1/8" male thread line nut & ferrule, you'll get what you need. Maybe NAPA?? I dunno.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 03-17-2008, 06:49 AM   #5
BurnoutNova
BurnoutNova's Avatar
i just bought a copper line kit from advance for my 67, the universal kit they have worked great. it was like 10$, so more expensive than the plastic one but will last longer
BurnoutNova is offline   Reply With Quote
Old 03-17-2008, 07:11 AM   #6
yenko427
yenko427's Avatar
Thanks guys for the help
Old 03-17-2008, 07:43 AM   #7
prg machine
Copper tubing will fatigue crack from vibration. Plastic won't. That's why they started using it. the plastic will outlast the copper hands down!
383 .040 over
Old 03-17-2008, 07:44 AM   #8
prg machine
The rooster knows!!!
383 .040 over
Old 03-17-2008, 07:52 AM   #9
prg machine
The rooster!
383 .040 over
Old 03-17-2008, 07:53 AM   #10
prg machine
once again
383 .040 over
Old 03-18-2008, 04:40 AM   #11
BurnoutNova
my 71 k10 has the originl copper tubing on it, and its still doing good
Old 03-18-2008, 04:49 AM   #12
ABHaulR
ABHaulR's Avatar
yep, all mine still have the original lines in them.
72 sub
72 blazer
67 truck.
no problems with them. i've known 3 people that have installed plastic lines and
2 of them have broke while driving. makes a mess. not worth my trouble.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 03-18-2008, 06:04 AM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
I don't believe plastic isn't allowed by NHRA tech
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-18-2008, 06:47 AM   #14
prg machine
Truth be known that is copper coated steel line and not copper.
I agree that the originals are still kickin'.........................reason is.............................they aren't copper!
383 .040 over
Old 03-18-2008, 06:49 AM   #15
prg machine
The rooster knows!
383 .040 over
Old 03-18-2008, 06:51 AM   #16
prg machine
Brake lines in these old rigs appear to be copper also...............but they are steel just like your oil pressure gauge line, and they copper coat to prevent corrosion!
383 .040 over
Old 03-18-2008, 07:30 AM   #17
BurnoutNova
my 1905 house has old copper pipes, and they havnt cracked yet. and i see them shake all the time when the water is shut on and off.
and wouldnt it make more sence to coat the inside of the brake lines with copper to? thats where the corrosion starts
Old 03-18-2008, 07:30 AM   #18
BurnoutNova
i dont get your rooster posts?
Old 03-18-2008, 07:38 AM   #19
prg machine
simple as that!
383 .040 over
Old 03-18-2008, 08:39 AM   #20
nyncompute
nyncompute's Avatar
Something tells me the Mods won't either
