Just Got the Cab Back From Media Blaster Need Help Please
I just got my cab back from media blaster and found that it was in overall good condition. I want to remove the drip rails and fix some swiss cheese in the roof and a pillar but i know nothing about metal fabrication. I am a very good welder but cannot bend or curve metal if anyone has a simple step by step for me or know an easy way to do this please let me know
thanks taylor
67' C-10 Project Truck Clinton Township MI My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=287690 |
Re: Just Got the Cab Back From Media Blaster Need Help Please
Man that looks like it will be alot of work. Do you want to shave the drip rails. Id look for onother roof skin if the rest of the cab is good.But if the rest is realy rotten you might want to look in to getting another cab it will save you time and money in the long run.
I had a buddy with cab rust like yours and he cut out the rusted areas and took them to a metal fabricator who was able to recreate the pieces fairly close. Then he brought them home and had a friend weld them in. He had to do some some body work to get the roof looking good, but now his truck looks great. I'm sure some else will chime in with more useful advice.
Dano
![]() ![]() It ain't yours, if you didn't build it! |
#4 | |
Grand PooBaa Member
Where would you buy a roof skin? I have the same problem, if not worse. I was told to buy a cab because it would be cheaper. |
#5 | |
I just got done fixing my roof and I'd never done anything curved before that. I just cut the area out and then traced the hole with some sturdy construction paper. Then I bought some sheet metal and cut out two patches to get the curve right and then welded it up. It'll take some filler but it really wasn't that bad and only took about 2 hrs to do. Here's some pictures of my repair.
Restoring a 68 SWB
Interested in a roof skin too. Going to look at a truck tonight that's supposedly in good shape but a PO put a sunroof in. Yuck! Would it be easier to do something like Rockcrln did with Project Trazer and cut the pillars and replace with another good roof?
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
Junior Member
![]() Join Date: Jun 2003
I would do like kyull67 said and make some patterns out of cardboard and repair the areas. You said you could weld so that is half the hurdle. My cab needed a lot of patching and I made patterns and formed the pieces from sheet metal 18ga with what ever was laying around. Oh yeah, I looked for the elusive rust free cab for a complete summer. Now that you have it blasted, you will see all of the areas that will need attention.
![]() Join Date: Mar 2008
Hello: Do you know what type of media material ws used to blast the cab?
He used a 3 step process - plastic media, walnut shells and sand in some areas. Turned out very nice
#11 | |
I am in kalamazoo mi and have 2 cabs, one I am fixing and a cab I am cutting up for patches to fix the other. If you want to patch your cab and your interested I can take some pics of it.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
#13 |
I used the other side of the roof and my hands. I also used aviation snips when cutting the patch to help get the curve. Once you get one side of the patch tacked on you can bend it more till it fits perfect pressing down with your hands or pulling/prying with a magnet of srewdriver.
#14 |
I was thinking about sandblasting my own but not sure if I will or not.
#15 |
The April 08 Custom Clasic Trucks Mag has an article on shaving the drip rails on the 67-72's.
Rob |
#16 | |
thanks
#17 |
I tried doing my frame myself and i will never try to sandblast another thing in my life - unless you are setup for it it makes a total mess! plus the media is just as expensive - i got a good deal on the blasting (i think) i paid $250 for the cab and the front grille. I would suggest to send it out
#18 |
Hey thanks so much! i have never seen the mag where do they sell it?
#19 |
Sounds like good advice. I will stick to sandblasting the tractor I am restoring.
#20 |
#21 |
Spanked once
![]() Join Date: Oct 2006
This is what I'm using for the same problem.
#22 |
Ok I will take some pics tomorrow.
#23 |
CAN'T FIX NOTHIN
you can fix that rust at home yourself like kyll67 did it's just time consuming , I am glad my 67 did not have any rust on the top !! but if it had I would have just fabed and welded !!!
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
#24 |
I wish I was a better welder. I have a small 120 volt wire welder, time to practice.............. small budget for body work.
![]() ![]() ![]() 1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
#25 |
The Older Generation
I guess I would try and find a junker cab and cut the pieces you need from it. Seems like it would be a lot easier.... Whenever I come across a bad cab with a good top I save the top off of it. I'm lucky though, I have room to store the stuff. LockDoc
