This is what happens when you have more than one project going,...
How many cross sills are used for a swb stepside bed and can someone show me their locations? I know there's two in front of the rear axle and the main cross sill at the rear, but I seem to have some cross sills left over. Thanx in advance. Dano
![]() ![]() It ain't yours, if you didn't build it! |
Re: SWB stepside crossills, how many?
There are four plus the one in the rear that's part of the bed. The first two from the cab back mount on the frame brackets, then the small one that only bolts to the wood and then one more that lines up with the holes in the frame before the rear cross sill. Hope that makes sense. Here's the best picture I have.
I have three tall sills and two short sills, do I use the tall or shorts behind the rear axle? Do I use a tall and a short? kyull67 thanx for the pics of the sills before the rear axle. They both look like the tall sills.
Dano
In order from front to rear they should be; tall, tall, short, tall, rear sill.
Hope this helps. Here's a better picture. Last edited by kyull67; 03-17-2008 at 04:34 AM. |
Thanx kyull67
