Old 03-17-2008, 12:18 AM   #1
rick0312
rick0312's Avatar
Help!!
I droped a washer down the first port. Where does it go and how can I get at it?
rick0312 is offline   Reply With Quote
Old 03-17-2008, 12:23 AM   #2
corn
Re: Help!!
Watch with a flashlight through the plug hole & lots of patience through the port with a small wire. Easier to pull the head & you might have to anyway if the valve is open & the washer went through...
corn is offline   Reply With Quote
Old 03-17-2008, 12:24 AM   #3
kyull67
kyull67's Avatar
Re: Help!!
If you have one of those magnet grabber tools, Id try that before taking anything apart.
kyull67 is offline   Reply With Quote
Old 03-17-2008, 12:27 AM   #4
DavesRide
DavesRide's Avatar
Re: Help!!
The first hole is a coolant passage. It goes down to the water passages around the cylinders. Try a flexible magnet. My only fear would be that it gets into waterpump blades creating a little havoc. It may just settle to the bottom and never be seen or heard of again.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 03-17-2008, 12:53 AM   #5
Luvlegs
Luvlegs's Avatar
Re: Help!!
tried rotating the block upside down? Just a thought
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 03-17-2008, 01:02 AM   #6
rick0312
rick0312's Avatar
Re: Help!!
i pulled the head and got the washer out. this is a new motor. can reuse the gasket or should i replace it with a new one?
Old 03-17-2008, 01:12 AM   #7
Cyclone44
Step Brother
Cyclone44's Avatar
Re: Help!!
I have heard that you can use reuse the head gasket from a fresh motor, I just don't believe it...But if it was my new motor it would have a new un used head gasket...Jmo
Cyclone44 is offline   Reply With Quote
Old 03-17-2008, 01:20 AM   #8
rick0312
rick0312's Avatar
Re: Help!!
never reinstalled a head gasket...do you use silicone before you apply the gasket?
Old 03-17-2008, 06:23 AM   #9
rick0312
rick0312's Avatar
Re: Help!!
well i went and picked up a new felpro gasket. I cleaned both the block surface and the head surface, removing any old gasket. i then cleaned both surfaces with acetone and let dry and applied the felpro composite gasket without any sealer (thats what the book said to do). I torque the bolts acording to the sequence in my manual. I feel like such an idiot. Do you guys think I'lll be ok when I fire her up?
Old 03-17-2008, 07:24 AM   #10
Cyclone44
Step Brother
Cyclone44's Avatar
Re: Help!!
If you got the washer out it sounds like you have it all covered...It should be good to go..Good luck
Old 03-17-2008, 08:18 AM   #11
rick0312
rick0312's Avatar
Re: Help!!
thanks guys....man it was a bad day!
Old 03-17-2008, 08:56 AM   #12
El Jay
Gone to greener pastures
Re: Help!!
Replace the gasket.
Gaskets are cheap---motors cost money.
Why take that chance?
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-17-2008, 08:58 AM   #13
El Jay
Re: Help!!
You'll be just fine, relax.
Why are you up so late?
Old 03-17-2008, 02:45 PM   #14
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
Re: Help!!
sounds like it turned out to be a pretty good day, after all.... you did get the washer out
i did that when i was a kid but down the carb went a butterfly nut and i couldnt get it. i went inside to grab a home made magnet rod and guess what was running when i came out! yep, good ol' pops decided to turn her over and see how well my tune up came out. boy was he po! oh well .
at least you caught it and found it!
could have been worse, ya know?
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-17-2008, 07:06 PM   #15
rick0312
rick0312's Avatar
Re: Help!!
Thnaks again. I did a search on fel-pro gaskets and I was happy to see that they have a good reputation. Only thing that really sucks is that my new GM warranty is now void! I did save the old gasket though. Hey I guess it could be worse...at least the washer fell right out when I turned the head over, and isn't stuck in some water passsage. I now have rags stuffed in all of the ports and dizzy holes....(Lesson learned)!
