03-17-2008, 04:47 AM | #1 |
Baggers post feedback
I found this link helpfull while researching my first air ride setup
http://67-72chevytrucks.com/vboard/s...d.php?t=129463 as I tried to locate parts i ran in to problem finding the plate and cup for the front i could not find at ***************** maybe i need a part # and link to distributer Also is it best to use RE7 bag on front as well as rear? Without a notch in rear frame How low can I go? Appreciate any advice on these ?????
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
03-17-2008, 04:51 AM | #2 |
Re: Baggers post feedback
same as the reply I sent to the PM you sent to me
Suicide Doors - 67-87 Fullsize Chevy Brackets [img]http://www.*****************/images/products/67-87_Fullsize_Chevy_Single_Port_Brackets.jpg[/img] Last edited by Shane; 03-17-2008 at 04:52 AM. |
03-17-2008, 05:00 AM | #3 |
thanks for the link still looking for bag choices
03-17-2008, 05:09 AM | #4 |
67-72 parts collector,…
Slams Re-7's. And you will be happy.
03-17-2008, 09:22 AM | #5 |
i have a set of air ride tech plates and suicide doors cups also have firestone bags pm me if you are interested
03-17-2008, 12:49 PM | #6 |
I went with the RE7s also and the plates and cups from suicide door too. Haven't driven the truck yet...but it sits low!
03-17-2008, 07:38 PM | #7 |
With the re7 bag setup in front what are the height changes? aired up and deflated?
also what changes can i expect on rear? will it need ajustable pan-bar? And with rear deflated will the axel meet the frame? These questions are for first time bag installer. Once truck is lowered I would like to tilt bed so tailgate will touch ground for power wheel chair to drive up. Thanks for the input All
03-19-2008, 03:59 PM | #8 | |
03-19-2008, 05:02 PM | #9 |
03-19-2008, 07:16 PM | #10 |
Questionable
Actually, not trying to be rude or anything, but most of your answers can actually be found in this forum, just within the last 10-14 days worth of threads. You just need to use the search feature. Search on "adjustable panhard" and then "frame notch" and you'll find at least 75% of your answers.
The first answer (the other 25% of your answers) greatly varies depending on your front end setup - whether you use dropped spindles, cups, etc. Did you look at the "Air Bag Installation Guide" in the FAQ - Truck Tech forum which shows step by step how to install an airbag setup with lots of pictures?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
