Old 03-17-2008, 06:16 AM   #1
prg machine
prg machine's Avatar
wiring question
I am putting together a wire loom for my truck. It is the one that runs along the firewall and down to the starter. I have found a splice that looks to be factory, but I am not sure, The funny looking white wire shown splices to 2 yellow wires. One goes down to the starter and the other to the distributor or coil I am not sure which.. Is this stock? what is the white wire and why is it a different insulation than the rest of the wires???
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 03-17-2008, 06:23 AM   #2
IBAPIGFARMER
IBAPIGFARMER's Avatar
Re: wiring question
white wire is your resistor wire for the points.
IBAPIGFARMER is offline   Reply With Quote
Old 03-17-2008, 06:24 AM   #3
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: wiring question
It is the OE resistance wire for the points distributor. Points can't be ran with full battery voltage. The wire to the starter goes on the "R" terminal. It supplies the points with full voltage while cranking for easier starting. If you are switching to HEI, replace it with regular wire & leave out the "R" circuit.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 03-17-2008, 06:33 AM   #4
BurnoutNova
BurnoutNova's Avatar
Re: wiring question
excellent description
BurnoutNova is offline   Reply With Quote
Old 03-17-2008, 08:20 AM   #5
prg machine
Re: wiring question
So if I am running MSD forget the whole schmear? Just run a hot ignition wire full 12 volt and tape off these wires if i follow you correctly. S????
If i understand correctly the resistance wire supplys the volts while running in a resistance state and while starting .the R returns full olts to the points for starting.
Since i am running MSD I will find a switched hot source and forget these wires.
383 .040 over
Old 03-17-2008, 08:54 AM   #6
El Jay
Gone to greener pastures
Re: wiring question
If you are running a "Full" MSD system you only need about 3, or so, volts to run the system, because the MSD box gets its power directly from the battery.
That's assuming that you wire it up according to their instructions.
In other words, you don't need to worry whether you activate it through a resistance wire, or straight 12 volts, or not.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-17-2008, 11:03 AM   #7
prg machine
Re: wiring question
"Full" MSD is what I got. Distributor, box, coil.
383 .040 over
Old 03-17-2008, 11:30 AM   #8
El Jay
Re: wiring question
That's what I have.
Love it to death.
Hit the starter & it fires.
