Old 03-17-2008, 07:36 AM   #1
Camper Power
Camper Power's Avatar
Question new question
the whole problem began with a headlight problem that i posted about.
http://67-72chevytrucks.com/vboard/s...d.php?t=283291
wen i went to chec the connections i first turned on the lights 2 c if the truck fixed itself. but wen i hit the switch nothing happened, so i thought it was the connection at the switch. wiggled and pushed on the plug but the lights still wouldnt turn on. i hit the horn 2 see if anything is was getting any power, and it didnt work either. tried the engine, nothing. so i chec the battery and it had power. 4 the hec of it wiggled the plug on the headlight that was causing me problems. i chec if that had did anything and everything started working properly.
so the question is would a loose plug at the headlights effec the rest of the truck's wiring?
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 03-17-2008, 07:55 AM   #2
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Re: new question
Seems like you have a hacked wire grounding out somewhere. On mine i had the wire loom on the fender well burn one wire bare and short out.
Maybe a spliced wire in the ignition switch melted.
jayharrell is offline   Reply With Quote
