Hey Watch this...
![]() Join Date: Sep 2007
Header Install, and Laughing at Prev Owner
So I embarked on the challenge of installing headers and flowmaster 50s on my truck this weekend, and I'm about half way though the job. It's very straight forward, but I have been laughing at what I was finding while ripping the old exhaust out.
First, I removed the clutch linkage Z-bar, but instead of proper cotter pins holding things together, rusting old paper clips! At least they were the cool plastic-coated ones, but still, not what I'd want as far as safety. Second, as I was removing the alternator, I realized that someone had WELDED the thing to the adjusting bracket/arm! They apparently didn't have a large enough washer for the bolt, so they just welded it up. The bracket (an Autozone special to be sure) is busted, so I need to get a new one. Next, when I was pulling out the old pipes from under the truck I was thinking how heavy duty the brackets were, holding the pipes up. Turns out, whoever installed the old busted exhaust used those plasti-dipped hooks that you use to hang things from the walls in your garage! They were threaded up into holes in the frame. I was laughing pretty good about that. I'm just glad that I didn't snap a single bolt, and that my headers fit. At least on the drivers side (haven't tried passenger side yet). Well, fit after I took out the Z-bar and removed the large canister oil filter, which was going to get retro-fitted anyway.
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
RIP BigDaddyDave ~7-23-09~ You will be missed~
Re: Header Install, and Laughing at Prev Owner
Well now i know that my po built 2 trucks, yours and mine! I have never seen such a mess in my life,as i have found on my truck. Every time i turn around,i find more of his handy work.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
65 - Chevy C10
thats home engineering at its best! no duct tape???
Resistance is Futile
I have found similar things in my truck adventures; its always comforting to know that they are corrected.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
