Old 03-17-2008, 11:10 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
POR-15 What do you thing about it?
Has anyone heard anything negative about POR-15? They say it's self leveling and you get a great finish. I am thinking about using it for my frame. How about on steel wheels? I know that the prep work is the most important step but more important, how is the product overall? Thanks, Harry
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-17-2008, 11:30 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: POR-15 What do you thing about it?
it is an awesome product... but READ THE DIRECTIONS... you'll find that it is not UV safe, and you'll have to paint over it.
Old 03-17-2008, 11:33 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
This will get you started.....
http://67-72chevytrucks.com/vboard/s...ghlight=por-15
lockDoc
Leon
Old 03-17-2008, 11:43 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
IMO it's a PITA to use & like said above it's not UV protected.
Have you looked at rust bullet?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-17-2008, 11:48 PM   #5
jlaird
jlaird's Avatar
personally i will only spray it. Its impossible to avoid runs when brushing it on. If it's a driver, who really cares though. Have to use a respirator when spraying.
jlaird is offline   Reply With Quote
Old 03-18-2008, 12:47 AM   #6
Longhorn Man
a respirator doesn't help, you need a fresh air system.
I have never had too much trouble with runs personally.
Old 03-18-2008, 01:35 AM   #7
prg machine
prg machine's Avatar
Use rust bullet. It is superior
Rust Shield is less expensive than the bullet, but still way better than POR
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 03-18-2008, 02:49 AM   #8
roj2323
i've used it and i actully used a 4in paint roller to apply it which actully was a great idea as i had no runs or anything else but i agree with what everyone else has said. the stuff is extreemly picky. oh when i did use it i found that the sample or "trial size" kit they sell will cover the entire bottom of a cab no problem and infact you will have a little extra.
truth be told though i'm not completely sold on the product. it smells like hell, is a pain to clean up, prep is extreemly time consuming and it takes nearly 2 weeks to get the crap off your skin.
ondrew
roj2323 is offline   Reply With Quote
Old 03-18-2008, 08:07 AM   #9
Longhorn Man
works longer than anything we've tested at work though... to include powedercoating.
Old 03-18-2008, 08:47 AM   #10
67_C-30
I have a radical idea!
67_C-30's Avatar
ondrew
You say that like its a bad thing. I'll give you that its aggravating, but it flat out works. I coated a 1/2 of a rusty old piece of metal with it and dropped in a 5 gallon bucket with 1 1/2 of granular chlorine for swimming pools and actually forgot about it. It was in the bucket about 3 weeks before I remembered my little science project and when I pulled it out of the bucket, the side w/o the POR-15 was literally gone. Totally disintegrated. The chlorine turned the POR-15 gray, but the coated metal was fine.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-18-2008, 09:10 AM   #11
Husker
Husker's Avatar
I like it, but have not used the other products.
It dries Hard and is impervious to just about everything. I painted the bed floor on my driver to stop the surface rust and did not topcoat it and still looks fresh but it was only a few months ago.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-18-2008, 10:00 AM   #12
Longhorn Man
none of them will stop rust in real real harsh environments, nor stop them forever, but POR is possibly the best one out there. we compaired it with powdercoat, the eastwood stuff, and one other... can't remember which one... but it lasted longer than any of them.
