Old 03-18-2008, 04:57 AM   #1
charlie72
trans help
my 72 was a stick shift converted to a 400 auto through the floor board. with a tilt auto coulmn(just purchased) what do i need to hook it up??
charlie72 is offline   Reply With Quote
Old 03-18-2008, 05:45 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: trans help
Is it a 4wd? If so, you'll need the 4wd auto linkage.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-18-2008, 03:21 PM   #3
vtblazer
vtblazer's Avatar
Re: trans help
Might be easier to do a cable shift linkage at this point, rather than try to find all the factory hardware.
Need more info though...
What are you meaning by '400 auto through the floor board'?
The shifter is through the trans tunnel and now you want to shift it from the column?
The 4wd shifter should take care of itself being the linkage is bolted directly to the t-case.
You might want to find a factory auto/4wd high hump trans cover as well, to make things look right or just plate off the stick shift hole and cover it all up with the carpet.
Welcome to the board, post up some pics when you have the time.
vtblazer is offline   Reply With Quote
