Old 10-28-2002, 08:13 AM   #1
Brewski*
Brewski*'s Avatar
How to check/clean heater motor?
Do I remove it there on the fire wall? what about inside the truck is there anything to check in there? I hear leaves blowing around and every once and a while one blows into the cab from somewhere. Is there a place to put a screen to block these leaves. Where I lived in Colorado there where no trees for miles so it was not an issue, now it is fall in Missouri so I have losta leaves~!
Brewski* is offline   Reply With Quote
Old 10-28-2002, 08:29 AM   #2
Huck
Huck's Avatar
Bout the only way to get it off is to unbolt it from the front. Sometimes it's best to pull the whole heater box as you can have all sorts of crud around the heater coil it's self. I believe you can pull the heater blower motor without major removals or to make it easy, support the hood and remove the hood hinge from the fender on the pass side. that makes taking the blower out very easy. If you want to pull the heater assembly, you may have to pull the inner fender or at least drop it down in the back. You may also find that mice made this their winter quarters and may also have sharpened their teeth on the blower fan by chewing thru some of the blades!!! While at it, stick you hand thru the quarterpanel access flapper holes (both sides) and see if your side boxes are filled with leaves and crud. They probalby need cleaning out as well--sorry but these trucks have some poor design areas and these are two~~~~ Huck
Huck is offline   Reply With Quote
Old 10-28-2002, 09:01 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
About the only way to stop those leaves from getting in there is to put screen under the cowl. I cut a piece of screen and hot glued it to the bottom of my cowl panel. Looks great when installed and no more whirling, buzzing leaves in the heater!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
