Old 03-18-2008, 07:57 AM   #1
MN Rooky
1971 4X4
MN Rooky's Avatar
Rear Brake Drum Questions
I have tried to do my homework but have come up with nothing. I have a 1971 3/4 ton and I am trying to check the back brakes. I apply the brake and nothing happens to the back brakes. No parking brake either. When I took the tires off I wasn't sure on how to take apart this type of drum. I looked it up in my books and search the thread history's. I came up with nothing to help me know what I will get myself into.
I started to take the 8 hex bolts off and it looked like gear oil coming out of the holes. Do I need to take off that end and then the wheel stud portion come off. Then I can get to the drum? Is the a seal of some type between the drum and the wheel studs that I will need to replace when I rip it apart. Or is it easier then I imagine.
Thanks for helping me out with all my beginner questions.
MN ROOKY
1971 Chevy 3/4 4X4, 4" lift, 33's
2001 Chevy 3/4 4X4 HD, 33's (Wife's Truck)
MN Rooky is offline   Reply With Quote
Old 03-18-2008, 08:09 AM   #2
Blue_71
Bloo
Blue_71's Avatar
Re: Rear Brake Drum Questions
first you take out the 8 3/4" head bolts.. gear oil will come out. i suggest getting new seals. autozone has some pretty nice outer seals for these (rubber with metal insert). they list as being for a dana 60, but it is a direct fit. i can get you the part number tomarow
you then will see an odd looking nut in there, it seems like from memory it has 4 or 6 slots in it for a special tool. i believe a 4wd front wheel bearing socket fits it, but im not positive. after taking off that nut, there will be a small plate (lock plate) remove it. there will then be another of the odd nuts with the 4 or 6 slots, remove that and the entire drum will pull right off, assuming your shoes arent stuck against it
now for my question to you-- what kind of trans do you have? i have a SM465 in mine with 3" blocks, and it seems to want to wheel hop everytime i let out on the clutch. do youi have any problems with your 4" blocks?
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-18-2008, 08:31 AM   #3
MN Rooky
1971 4X4
MN Rooky's Avatar
I wish I knew if it hopped too I haven't had it on the road yet. I have a 205 trans and 4.10 gears. The lift kit was last months project. I have had it in the shop for 2 years working on it. I want it to be on the road in 3 months. Thanks for the info. I figured it would be something like that. If you come up with the number on the part that would be great. Tomorrow will be brake disassembly.
MN ROOKY
Old 03-18-2008, 08:49 AM   #4
Blue_71
Bloo
Blue_71's Avatar
sounds like yours is alot like mine-- its also a NP205 with 4.10s. mines been on the road a 2 months. i only drove it once on blacktop with no blocks, and that was 5 years ago, so i have no idea if it did it before or not
1989 Chevy K2500
Old 03-18-2008, 07:16 PM   #5
OldCreek
OldCreek's Avatar
looks like an H052 rear end.. I would have guessed a 14blt for that year. Anyways, the spindle nuts should be 6 prong... you could always loosen them with a screwdriver/hammer. But, buy the socket to tighten them. The hub/drum should come off together. Try not to damage the lug studs... they don't make the exact size anymore and it's hard to find them. But, you could buy the same size lug in a longer length...shouldn't be a problem.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-18-2008, 07:17 PM   #6
OldCreek
OldCreek's Avatar
oops... it's a 71.... i thought it read as a 73...that's the right axle.
also, don't damage the spindle lock ring tabs.
Old 03-20-2008, 11:02 AM   #7
68K20 x Drill
http://pirate4x4.com/tech/billavista/14b_bible/14b.pdf
nobody describes it quite like the army. Yours is a little different, but generally similar.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 03-26-2008, 07:41 AM   #8
bomar
bomar's Avatar
where did you get those u bolts at
72 chevy LWB 3/4ton 350/th350/np205 with 6inch lift on 36" TSL super swampers power
bomar is offline   Reply With Quote
Old 03-26-2008, 07:50 AM   #9
MN Rooky
1971 4X4
MN Rooky's Avatar
The U bolts came with the Rough Country lift kit. I know at Fastenal they can make any size Square u bolt. Not sure what it would cast. Sorry I'm not any more help on this one.
MN ROOKY
Old 03-26-2008, 07:52 AM   #10
Blue_71
Bloo
Blue_71's Avatar
here ya go if you still need it:
http://www.autozone.com/N,11201948//...eResultSet.htm
felpro rear axle flange gasket P/N 55350
1989 Chevy K2500
Old 03-26-2008, 08:24 AM   #11
MN Rooky
1971 4X4
MN Rooky's Avatar
Cover me I'm going in....
I got the bolts off and pulled the cap off. To my surprise, it is attached to the shaft. Only about a 1/2 cup of oil came out of the axle. I got the socket to remove the spanner nuts. The hole stud assembly and brake drum came off together. The brake pads look like the have enough like in them but the cylinder ends are cracked and the adjustment wheel is in rough shape. I nee to clean it up and see what I need.
Thanks for everyone's help. I'm sure I'll be asking more questions.
MN ROOKY
Old 03-26-2008, 05:52 PM   #12
Yukon Jack
Post Whore
Yukon Jack's Avatar
Thanks for taking the great pics. I'll store this link for reference - I'll need it some day I bet.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-27-2008, 05:01 AM   #13
va_tlc
va_tlc's Avatar
yep that is a great picture, how are your drums? hopefully they will be ok, i belive those wheels cylinders are pretty high if i remeber right, good luck.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 03-27-2008, 07:06 AM   #14
MN Rooky
1971 4X4
MN Rooky's Avatar
From what I know the drums look okay and the bearings look pretty new. I'll get a picture up tomorrow of the drum. I looked in LMC at the cylinders and they were asking $30. If you know of anyone cheaper let me know.
MN ROOKY
Old 03-28-2008, 03:29 AM   #15
MN Rooky
1971 4X4
MN Rooky's Avatar
A few more pictures. One of the inner nut and one of the drum.
MN ROOKY
Old 03-28-2008, 10:54 PM   #16
va_tlc
va_tlc's Avatar
i belive thats about what i payed for the wheel cylinders locally parts store, its hard to see the drum is it good and smooth? and after you get the whole thing back toghther, remeber that oil that came out when you took your axle out? you need to get more back in there for the bearings, so when you first drive it drive on a incline a hill or such to get oil back out there, do that one each side, good luck.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 09-06-2009, 07:38 PM   #17
akubovic
66 C20 Long Step
akubovic's Avatar
MN Rooky, Thank you for this thread, your pictures are a godsent for me, I have a '66 3/4 ton 2wd and thanks to your pics I think I know how to tackle the rear brakes on my chev.
akubovic is offline   Reply With Quote
Old 09-06-2009, 07:47 PM   #18
akubovic
66 C20 Long Step
akubovic's Avatar
By the way do you know what size the socket for the spanner nuts?
Old 09-07-2009, 12:00 AM   #19
MN Rooky
1971 4X4
MN Rooky's Avatar
I don't know what size it is off hand. I will check tomorrow for you and let you know. Little update. The brake drums on mine were shot and at the cost of $240 each drum I couldn't afford to replace them. I ended up swapping the rear end out for a 14 bolt for $100.
MN ROOKY
Old 09-07-2009, 01:42 AM   #20
onlyifihadachevy
Yea when i ended up putting brakes on The first set was wrong, and cheap like a 100 bucks and 50 for the clyinder, then we got the right one, then the bill came 300 for the drums and shoes and 88 for a cylinder and that was a discount, no labor i did it myself. Next time i'm getting a disc brake kit.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 09-07-2009, 09:49 PM   #21
MN Rooky
1971 4X4
MN Rooky's Avatar
The spanner socket has 6 posts on it. I got it at Napa, part number KD2770.
MN ROOKY
Old 09-08-2009, 08:40 AM   #22
akubovic
66 C20 Long Step
akubovic's Avatar
Thank you once again.
Old 09-09-2009, 11:31 PM   #23
cobinder
Everything is work in progress
cobinder's Avatar
Convert to rear disc brakes you will love them.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 09-11-2009, 04:35 PM   #24
Ridgeback
Your picture of the rear shoes indicates that the strut bar for the parking brake is missing. Unless you removed it before you took the picture, that is the reason the parking brake does not work.
Ridgeback is offline   Reply With Quote
Old 03-13-2011, 11:12 PM   #25
zicc1835
zicc1835's Avatar
i would like to thank you both i am going to pull the backs off my 67 3/4 in a couple of days and this will help a whole lot .. had big trucks , years ago almost the same... i have a question i replaced the master and bled all 4 bleeders pedal is up and hard but brakes are still spunge at best ....after driving a while push down goes half way down and pedal pushes/ bumps like a skip back at my foot spungy need to mash on her to get one wheel to lock dont know which one locked believe it was rear couldnt see the tire mark any ideas
zicc1835 is offline   Reply With Quote
