03-19-2008, 12:19 AM | #1 |
Enjoy your truck
lower control arm u bolts
I am getting everything ready to freshen up the front suspension in my '63 and am looking for someone who can supply me with the four "U" bolts that attatch the lower control arms to the front crossmember.
My local GM dealership doesn't show them any more and I don't want some generic piece of junk bolt. Any ideas who can supply the proper bolts? Greg
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
03-19-2008, 01:05 AM | #2 |
Re: lower control arm u bolts
73-87 should fit also try autozone or napa etc. Maybe in the help section of the auto stores. Worse comes to worse junk yard 73-87. To be honest with you the ones that are on it probably aren't that bad, have you checked them. Most of the time they get so packed with grease and grime they don't have a chance to rust. Mine were still like new once i dug all the grime off.
03-19-2008, 03:55 AM | #3 |
Enjoy your truck
Thanks for the tip.
I had my GM parts guy look up the 73 "U" bolts , but I wasn't going to pay $11 each for something that would not fit. I will try NAPA. I want to have some on hand in the event the original Canadian bolts snap when I disassemble them.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee Last edited by Greg63; 03-19-2008 at 03:56 AM. |
03-19-2008, 04:00 AM | #4 |
Resistance is Futile
I cant remember where I got mine when I did the rebuild on my truck. I can tell you that there are 2 sizes; maybe heavier size for 3/4 ton? Anyway, I had to elongate the holes to fit the new u-bolts in the x-member. I didnt enjoy doing it!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-20-2008, 08:12 AM | #5 |
60-66 Nut
I would suggest upgrading to the larger dia ones used '73 and up. I had two of the original ones on my Suburban break....really not sure why they broke. Even though I replaced them with the original size I haven't had one break in several years. But if I were you and I was disassembling the front suspension anyway, I'd upgrade....plus there must have been a reason GM uped the size.
03-20-2008, 03:28 PM | #6 | |
Enjoy your truck
Thanks for all the suggestions. Now all I require is one upper ball joint - a Moog K6024 or a GM piece - and I can start the rebuilding process. Does anyone have one upper ball joint available? Greg
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee Last edited by Greg63; 03-20-2008 at 04:01 PM. |
03-20-2008, 09:29 PM | #7 |
65 - Chevy C10
hmmm... trying to think what ubolt ur talking about on the control arms.
03-20-2008, 11:09 PM | #8 |
Enjoy your truck
There are two on each side that hold the lower control arm cross shaft to the front crossmember.
03-24-2008, 03:40 AM | #9 |
Hi Greg,
Here's what you're looking for (if you want stock): http://www.classicparts.com/prodinfo.asp?number=74-351 But as others have pointed out, the original was 7/16" and the later stuff is 9/16". I'm going to switch these on my 64 as well, and was thinking about going with the 9/16 and just drilling out the crossmember.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
03-24-2008, 08:14 AM | #10 | |
Enjoy your truck
I picked up the GM 9/16" bolts and will be drilling. They were about $9 each. Greg
