03-19-2008, 01:23 AM | #1 |
Question: A/C ducts - oem or aftermarket
LMC sells the A/C and defroster hoses in both an aftermarket and oem version, with the oem version being much more expensive. What's the difference and what would you recommend?
03-19-2008, 02:17 AM | #2 |
Old member
Re: Question: A/C ducts - oem or aftermarket
The factory ones are a felt canvas type of material where the aftermarket ones are plastic rubbery material. Myself I would go aftermarket. If I had a orignal truck and wanted to keep the look right then orignal.
03-19-2008, 04:59 AM | #3 |
The original ones fit very tight and can be difficult to put on, but once on they will stay but if they tear, they are done, they will completely unravel. The aftermarket ones are plastic and remind me of dryer hose. They look out of place in my opinion but I think they will actually put more heat/ac to the windshield. I guess it all depends on your budget and how you want the truck to look.
03-19-2008, 06:38 AM | #4 |
I got mine from classic american parts and they didn't cost that much if I remember correctly. They fit snug b ut the defrost blows real good and strong now.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. |
03-19-2008, 06:56 AM | #5 |
Gettin By on Gettin By
I put the LMC non OEM in last weekend. Very tough plastic. Like a shop vac hose. But still fit pretty nice after a litle trimming to fit lengthand useing a blow dryer to give them some streatch. I have to agree that i was afraid of the felt tearing on me on the OEM style. I haven't run these at all, but as far as instillation, pretty quick.
03-19-2008, 12:45 PM | #6 |
It's a really fun job no matter what you use. I went with the OEM style and I had to do very little trimming, but give yourself a lot of time. Use a shop manual or one of those 'assembly manuals' and route them exactly as shown.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
03-20-2008, 02:26 AM | #7 |
I vote for oem felt, but then, that's just me. They fit better and don't look cheesy. You can abuse the oem felt ones pretty good before they will tear. I always had a problem with the plastic ones falling off on the drivers side. pretty annoying. I wound up using an electrical tie wrap to keep it on. The plastic ones don't look original, but then again, no one sees this. As a matter of performance, they are more than likely equal. Don't see how they could be any different. Usually when people are replacing this it's because the old ones were messed up and probably contributing to a vent not blowing properly.
03-20-2008, 02:31 AM | #8 |
Heres a routing pic. Helps alot. I had trouble getting around the wiper moter untill i looked at this.
03-20-2008, 05:04 PM | #9 |
Thanks for all the advice. I decided to go aftermarket, as mine is a custom truck anyway, so I didn't care about factory look. I have installed 1 oem style hose before and it was a bear. Hope the plastic ones will be easier to install. Will let you know when I get them in.
03-20-2008, 07:58 PM | #10 |
I went aftermarket also. Just a lot cheaper and they function the same.
-Scott- |
03-20-2008, 10:45 PM | #11 |
I just did mine last weekend got all the hoses from salvage yard $2 brand new .Yeah look at the routing diagram or you will fight it forever been there done that.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
03-20-2008, 11:55 PM | #12 |
I went with the more expensive OEM type hoses. Installation was a breeze, and they don't have that cheap harware store appearance...
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
