A few easy questions.....
Sorry if these questions are lame, I am new to this whole 67/72 truck thing. How do I clean all the crap out that's under the cowel? I pressure washed under the hood and there seems to be a bunch of pine needles and crap trapped in there.
Does anyone sell front fender patches for the lower part in front of the wheel arch for a '72? LMC shows patches for the rear of the arch... That's all for now, I have a bunch more questions but this will get me started...thanks! |
Active Member
![]() Join Date: Jul 2007
Re: A few easy questions.....
Cleaning under the cowl..
I removed the cowl and with my hands removed as much as I could. I then rigged up a long vacuum hose to my shop vacuum and got most of the stuff that I could get to from the top. Then I went inside the truck and removed the vent covers. Reached in with my hands and scooped out whatever I could reach. Be careful, I've heard some guys have had all sorts of critters living in there, including a rattle snake! Then, again, used the shop vac to get the rest of the debris out. Washed out with water hose and made sure the hole was not plugged. Last thing I did was to cut me a cowl screen (do a search-lots of ideas) to keep the leaves out. We don't have pine trees around me so I just used Gutter Guard from Lowes and cut the length with scissors. |
Dave's not here, man
When I cleaned mine out I removed the cowl and opened the vents in the cab. I blew compressed air from the cowl area down through the vents and it worked really well. Of course, it makes a mess in the cab, but I just swept it out. You can also get most of the big stuff out with your hands when the cowl is off. BTW,
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
So I guess the cowl is just bolted in ? I didn't see any exposed hardware, it must have been up under it acessed from the engine compartment I guess. Anybody on the fender patches question?
Thanks! |
454 MAKES IT ROAR
Lift the hood there is a bolt either side, and open the doors there are bolts either side there, a line of screws where the back edge of the hood meets the cowl and four more at the bottom of the windshield, and remove the wipers.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Active Member
Dittos on what eightbanger said.
I want to add that when removing the wipers-at least on mine- lift the arm up as high as it will go to release the clip that holds it in place. Then carefully lift the arm base up using a pry instrument. I use a prybar with a towel under it to protect the paint and pry the arm up from the back side. At the same time you may have to wiggle the arm some to coax it up. It may be stuck if you haven't done this in a while. |
about the fender patches
i havent looked through an lmc in a few months but lmc did sell front patches i bought a couple for my dad as a bday present they worked pretty good but i much rather just english wheel my own and patch it without spendin the money but thats not an option for everyone but yes the patches are sold if lmc dont sell them anymore goodmark might
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
i decided to take a look for the parts u were lookin for and i didnt see them on lmcs website but i found another website that has them and alot of other panels
http://www.toolshedofamerica.com/Bod...k-up_67-72.htm ive never ordered from this place but my friends dad has and what he ordered seems pretty good quality and the prices are pretty reasonable good luck with ur project
Active Member
Try the vendors that support this site first, if you can. GMC Paul has the patch panels and so do others. I never can remember where the list is but there's one. The forum support staff knows where the list is...
I think this may be what you need. http://www.gmcpauls.com/pictures/67-...atchpanels.jpg http://www.gmcpauls.com/Patch_Panels.htm |
someday it will be done!
I recall seeing a post by one smart fella here that fabbed a door into the side of the air box(hidden of course) that would allow easy access to the lower area of the box where all the crap gathers.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
Thanks for all the replies guys, great info!!!
I am a Referee of life.
There is a drain in the bottom of the area.It can be found under the truck.Make sure it's clear so water will drain.While you're laying there on your back in the water(I never remember to do it first either) check the drains in the bottom of the doors.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#13 |
Gettin By on Gettin By
I got a strip of gutter guard my self. Thought i had an origonal idea there. LOL.
My blower motor had built up alot of leaves and junk too. This is a must do or it'll rust out your inside vents, fire wall, and the bottom of your AC or heater ducting in the housing under the hood. Makes a mess of your heater core too. I'm thinking about building the gutter guard into the air cleaner. Like a cheap man's Copper Head cleaner. Kind of tie it all together. Last edited by jayharrell; 03-20-2008 at 04:52 AM. Reason: more thoughts |
