Junior Member
small block serpentine system on a big block
Here's my small block serpentine system on a big block chevy using an adapter kit.The kit adapts a 94 or so year small block system to any standard deck big block.
![]() Join Date: Jun 2006
Re: small block serpentine system on a big block
Got any part numbers? Where did you get the kit.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
![]() Join Date: Aug 2005
x2
nice. does it come with the reverse water pump or did you have to buy that separately?
Junior Member
I have all the part numbers and info.When I get Home in a few hours I'll post all the info.thanks Mike
Junior Member
I just seen where thest guys are selling the kit on evilbay.I don't know how to do the link thing but the item number is 330220700998 or you can search big block serpentine.It is 110.00 for the kit, all the kit is adaptor plates to bolt a small block system up.I had to round up all the pieces.All the detailed information like part numbers etc. is in the evilbay listing.I got all the brackets at a local u-pull it for about 30.00 bucks.I choose to buy new air cond. compressor, one wire alt, idler pulleys,water pump etc. I did chance a used power steering pump.All the small block systems are real easy to find, that's why I choose to go this way.
thanks Mike |
