03-19-2008, 06:15 AM | #1 |
Married to my Truck
HELP! leaf pin will not align in hole of axle
I took one leaf out, the bottom one, and cut the centering pin. This was done on only the passenger side. But I drop the jack and the pin will not fall into place in the hole on the axle. I can see the head of the pin thru the hole, it rests just ahead outside of the hole. Almost seems like if I could push the wheel forward it could seat, but I have tried that but it doesn't budge. I have been working on this for 4 hours!! Someone help please! suggestions, solutions, anything!!!
1982 Chevy SWB C-10 (AKA my pride and joy 1989 Chevy Suburban (under construction) 1989 Honda Civic sedan (work car) |
03-19-2008, 02:22 PM | #2 |
Next!
Re: HELP! leaf pin will not align in hole of axle
Just got done doing the same thing on my dually. Had no problems and replaced a leaf on the passenger side. Did you take the drive shaft out?
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
03-19-2008, 03:31 PM | #3 |
One shot, one kill.
Drilling: Jack the truck by the axel tube directly inside where the spring perch is. use a come along or porta power to move axel front or back. Left or right alingment is accomplished with a BFH to the spring. Jacking by the frame allows the spring to arch which moves the center bolt forward. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
03-20-2008, 07:30 AM | #4 |
Married to my Truck
Thank you so much james, I went out and finally bought a come along and it did the trick!
03-20-2008, 08:16 AM | #5 |
Happy to be here
I usually just kick the spring and/or axle till it falls in place...
03-20-2008, 12:30 PM | #6 |
One shot, one kill.
Drilling: Glad I could help. A litle note to N2 with a grin on my face, I'm near 60, the only thing I can kick is the dog, the cat, my girlfriend or the bucket. I can't even kick myself in the ass when I screw up. LOL, jim
03-24-2008, 10:09 PM | #7 |
Make sure the tire on the opposite side isn't holding any load... When it is drooping with no load (truck on stands), it will rotate and allow the pin to line up much easier... If not, just get mad at it and kick/push it in.
03-24-2008, 11:18 PM | #8 |
Parts and more parts
Try jacking up the truck and use a couple of big C-clamps.
03-25-2008, 01:55 AM | #9 |
03-25-2008, 02:00 AM | #10 |
that's what I do when messing with the leaf springs, makes it easy to maneuver back into place.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
