senior member
installing my ECE drop kit have a question
has anyone else whos installed this noticed after thye install it theres is alot more toe in now than there was before? maybe its just me but it seems i have more now than i did before
69 GMC bagged |
1972 Chevrolet SWB
Re: installing my ECE drop kit have a question
its very common.
as camber changes so does toe in/out and caster,it all works togehter
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
senior member
thanks i guess ill be getting an alignment anyways when im done so no big worries
69 GMC bagged |
1972 Chevrolet SWB
Generally speaking,and frt end part replaced needs alignments either done or at least checked. There are very few parts that wont effect the alignment some,and tires get expensive..
Anytime you tear into the front suspension you should have an alignment done, even if its just a balljoint.
Deffinitly have the front end aligned... I did 2.5" drop spindles on my pickup and went through a set of tires before I even realized... learn from your mistakes i guess
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
