ccp rear adj track arm - what is wrong
does this look right? what is wrong?
track arm measures 39" center to center with adjustment turned all the way in??? i am running 5 inch drop coils. i know i need to center the rear but should i move it that much? thanks |
Under Construction
Re: ccp rear adj track arm - what is wrong
Hmm, thought it was suppose to be 36 in length.. here is a link... http://www.classicperform.com/Store/.../6572CDTBK.htm I think i recall when lowering 5 or more the mounting location of the track bar is changed as well, to compensate for the geometry change. but i cannot recall where i read this. There are plenty of members that have been down this road, so hopefully they will chime in soon.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 03-19-2008 at 05:23 PM. |
1972 Chevrolet SWB
Can you show us the other end and its mount?
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
THis might be a dumb question, but is the rear centered in that photo? I know the rear can move a lot from side to side which might be the problem and you just need to scoot it over a little.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 03-19-2008 at 05:56 PM. |
here is a pic of the other side. don't mind the shock mounts - i have now put them on the right way.
these bars use the factory upper mount on the driver side frame??? |
1972 Chevrolet SWB
whatnow123, brought up a good point...........do a quick measurement from the bulge of the right tire to the frame rail and the left tire to the frame rail to see if the frame is over to the right more than the left.
I wanted to see the right side mount to make sure it was mounted correctly.
go check and make sure the rear is centered. The track bar uses the factory mount on the frame and attaches to the other trailing arm.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
cool - i will measure and check the difference.
if the rear is not centered - any ideas on how to center? ratched strap??? thanks |
Dave's not here, man
That's what I used. I bought a heavy duty one and it worked great. I'm not sure of another way to do it if you're by yourself.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Texas Big Wig
I've never owned on of these, so I dont know how you are supposed to install them, but it looks to me like the bracket on the track bar / trailing arm is up side down ???
Looks like you pan hard bar would hit the frame when the axle is all the way up in your notch But I dont know, just making an observation |
#11 | |
Old member
I installed mine over the holiday's and had to pull the body over with a strap. It looks as though the frame and trailing arms are way off. The u-bolts on the rear end should come right under the frame when they are compressed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#13 | |
if i pull the frame to install the bar, i would then use the adjusting rod to center the rearend? any pics of one of these installed.. i searched over the weekend but only found the adjustable factory replacement and the ECC brand thet i think is different |
#14 |
Old member
In my earier post I said I pulled the body over I meant the frame. I attached a strap to the trailing arm and then to the oppiste side of the frame and centered it up. The frame mount for the arm to the trailing arm mount and pulled it until it lined up.
#15 |
Dude, you have a stock rear end right? At least I saw the stud mounted on the rear end. The 39 inch track bar is about 15 inches too long and does not need to be mounted to the trailing arm unless you want it there. My truck is lowered four inches using lowering blocks and drop springs and I have no clearance issues. I just measured my track bar and it is 24 inches from center of the mounting stud to center of bolt on the mounting point on the frame. Also when you center the rear end use a ratcheting strap as the other guys suggested and measure from which ever point are fixed, eg outside edge of frame to inside edge of rear discs.
![]() Last edited by meekdog; 03-20-2008 at 05:12 AM. Reason: Correct/Add additional info |
#16 |
1972 Chevrolet SWB
SIMPLE SIMPLE SIMPLE
people are trying to help but your not giving back here like helping with your measurements. With NO shocks you could stand near the right rear of your frame and by pressing your leg against the frame rail pushing left you can make the frame move over 3-4 inches I bet.......its that easy. I just measured mine outside in the rain,took 5 minutes tops. the bar,35" center to center from sidewall of bulge of tire to frame 7 1/2 EACH SIDE (ROUGHLY) directly above the center above the trailing arm (dividing line in each one) to side of frame 4 -4.5 each side. here you go NOTE this is generally speaking........the buldge of the tire ON TOP to the frame,and then directly above parting line of control arm to side of frame. ![]()
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. Last edited by slammed1; 03-20-2008 at 04:57 AM. |
#17 |
thanks for all the info - i will be measuring this tonight
#18 |
UPDATE:
ccp sent me the wrong bar : see photo it is at least 3" longer than the standard length i purchased the ECE trackbar that is prebent to clear the alm diff covers. it does clear the ultimate 12 dif cover. the piece slipped right in and i will fine tune it when i get the body back on. thanks for all the help guys. REAR COVER THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=273701 |
