lowering spindles vs. Lowering control arms
one vs. the other the good the bad the ugly. Any thoughts advice. I'm going for 5-6 front drop so what ever way I go coils will be used as well.
thanks |
BAD BOW-Silverado XST
Re: lowering spindles vs. Lowering control arms
Spindal keep the factory geometry for alignment. Springs push the wheel out. I would use both for any drop more than 3".
spindles are the cheapest way to go just bought mine for $139 plus shipping, LCAs are good alco but about double the price.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Neg -
-Spindles push the tire out. -LCA's decrease your ground clearan (under the lowest point of the truck and some generic shops "can't" align them properly. Pos - Spindles don't effect the ride, and are generally easier to have a generic shop to align them LCA's don't affect ride and keep the wheel in the same position. You can't use these together.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#5 | |
Also depending on what wheels you have, there may be some grinding on the spindle for clearance. A 6 inch front drop (3'' spindle with 3'' spring) may be hard to drive without the aid of bags unless you live where there's only fresh tarmac and no speed bumps.
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
I had 3" spindles and 3" springs on my '80 and had no issues with "pushing the tire out" the spindle is exactlly the same as the stocker bit has the axel portion moved up.
BeWarE tHe eViL CrAnkTOe!
so what do you use for a 4/6 for the front ? 2 inch spindle and 2 inch spring?
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
yeller
Dave, 3" spindles and a 1" spring. Bell Tech offers each.
I believe Western Chassis has 2.5" spindles and maybe 1.5" springs. I have never seen a drop spindle increase track width in front...my Bell Tech ones didn't at least.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 03-19-2008 at 09:54 PM. |
I've done it both ways on different trucks. In my opinion, there is no benefit to LCA's that justify the extra cost over a quality spindle.
- Greg |
![]() Join Date: Oct 2006
Were did you get them from ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
http://cgi.ebay.com/ebaymotors/ws/eB...m=370031278766
these are 3" and they have them for any configuration, my burb is a 3/4 ton with 1.25 rotors, 8 lug of course. |
I thought if you went with a 3" spindle you had to do some grinding if on 15" wheels?
#13 |
#14 | |
yeller
I had to trim my LCA to clear my 15" wheels after the drop spindle install.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#15 | |
#16 |
Right in front of you.
Most likey will need to do some "slight" clearancing on the caliper if using 3" spindles and factory 15"s....as well as aluminum aftermarket 15" wheels, as aluminum wheels are thicker in the cross section.
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
#17 | |
It Is What It Is,,,,
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
#18 |
#19 |
Yea let me know !!! Be safe on your trip
#20 |
Happy to be here
![]() Join Date: Mar 2000
Good luck with it. Those are AIM/Chassis Tech spindles.
Look at the email address...CHRIS@AIMIND.COM
#21 |
#22 |
So Zombie how did the install go ?
#23 |
Very well, I had the spindles done in about an hour and a half, no issues, the hardest part was the left rear shackle, on a burb you have to make an access hole in the spare tire well for the bolts to come out, the spindles were as nice as the last set I used, which were westerns I think, the toe was way out of wack because they move the tie rod attachment point in to clear wider wheels, all in all very pleased, I have heard all the negitive things about AIM products but the spindles were fine, and for the price you cannot go wrong!!!
#24 |
Very cool thanks !!
#25 |
Can you run stock shocks if you do a spindel only drop??
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab Last edited by RWJJR; 03-22-2008 at 05:21 PM. |
