Old 03-19-2008, 07:48 PM   #1
TLoz
Transmission Cross-member braces
Hi everyone,
I've got a 1978 4wd burb frame I'm working on. Finished painting the frame this weekend. I pulled off the cross member in order to clean/paint under it. I wanted to verify if the x-member went under or over the frame rail (I would have put it on top of the bottom rail of the frame-GM put it under), but I noticed in the pics that it should have a couple of transmission braces running from the top of the frame rail toward the center of the x-member. The questions is, were these standard/required on all k's and where to gettem'. The x-member had been removed at some point in it's life, since the bolts were to long. Thanks in advance, Tom
TLoz is offline   Reply With Quote
Old 03-19-2008, 08:52 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Transmission Cross-member braces
Mine goes under:
There are top brakets too that you cannot see in this pic.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-20-2008, 10:55 AM   #3
68K20 x Drill
Your bolts are not too long,they are missing the spacers-About 1" long heavy wall tubes.
I think they exist to reduce the chance of bolts backing off.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
