Old 10-28-2002, 02:19 PM   #1
Project1970
14.1 @ 96MPH
Project1970's Avatar
Restore?
Anyone ever actually used Restore in their engine and seen an improvement? I'm going to dump a can in next time because while I'm not losing much oil and my compression is fine, I know the rings are having a hard time dealing with 10.0:1 compression...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 10-28-2002, 02:32 PM   #2
ckhd
ckhd's Avatar
Thumbs down
I've never used it before, but I have a *really* hard time dumping miracle crap into my engine. If it sounds like snake oil, it probably is... Plus, it makes me nervous as to how it "restores compression". I wonder what kind of sludge/gunk is in it that will either stick to my cylinder walls or to my pistons, or to my rings. The same sludge is going to stick to my bearings, oil galleys, valves, tops of the pistons, etc...
I view it in the same catagory as that "Aluma-seal" crap for radiators.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-28-2002, 03:08 PM   #3
Brewski*
Brewski*'s Avatar
Don't use Restore. I had a head go bad 100 miles after using it and a friend lost his motor. No good~!
Brewski* is offline   Reply With Quote
Old 10-28-2002, 03:29 PM   #4
vfrdude
vfrdude's Avatar
Your not burning oil, and your compression is fine. What makes you think that you're rings are having a hard time with 10:1 compresion???? 10:1 isn't that high, although you probably have to run premium.... I would leave everything the way it is...
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 10-28-2002, 05:20 PM   #5
Project1970
14.1 @ 96MPH
Mass quantities of blowby. It took one PCV to carb vacuum, one filtered breather on a PCV valve, and one unfiltered, unvalved breather before it stopped trying to push oil out of the filtered breather.
