400 BB vs 350
Got my eye on a couple different trucks. One of them is a 72 c20 with a big block 400, others are 350's. Wondering what peoples opinions are on the 400, good / bad , problems , costs , ect. I like the idea of a big block, but have never heard much about this motor. Any thoughts are greatly appreciated !
Re: 400 BB vs 350
Parts are more expensive. Expect around 10MPG if that's important to you.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
Re: 400 BB vs 350
Millage would not a big issue, would just be something to put around in from time to time. Wondering more about power and reliability.
Re: 400 BB vs 350
I'm in the midst of rebuilding one now. Cruiserman is right, can be more expensive, but as with anything it depends on what you're expecting perfomance-wise.
Re: 400 BB vs 350
Both engines would be primarly stock. Just didnt know if there was any great advantage to having that 400. Im assuming it would have a little more hp and torqe.
Re: 400 BB vs 350
It should....is it a 402, 396 or a 400? If it's a 400, it's a small block as well. Both the 396 and 402 are more powerful than a stock 350. The advantage is the truck will be faster and more than likely more valuable if sold.
Disadvantages are that parts are higher and gas mileage is less. That said anyone who buys a truck like this for mileage needs his head checked. I'd get the BB if it's in good shape.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 03-19-2008 at 11:03 PM. |
Re: 400 BB vs 350
Its the 402 ci
![]() Join Date: Apr 2001
Re: 400 BB vs 350
I own a 402 c20 and it is quite thirsty.... 10mpg is pretty accurate and in our colder weather i was around 7-8 on a few trips last month... welcome to another Minnesotan!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Re: 400 BB vs 350
402's are great motors. I know someone who drives one daily to his job in Dallas. He gets around 10 mpg in town if he feathers it....something I fail to be able to do.
I get 11-12 mpg [sb 350] with what's known as a lead foot. If I could feather it who knows? My '67 will probably be a big block....either a 396 or 402.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 03-20-2008 at 01:22 AM. |
Re: 400 BB vs 350
My stock 402 truck has the 3.07 axle and I got 13 mpg city last time I checked.
The C20 you are looking at will probably be closer to 10 mpg as said above because of the gearing. |
![]() Join Date: Apr 2000
Re: 400 BB vs 350
get the bb you will like it!!!
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
Re: 400 BB vs 350
I had a big block in a chevelle and it was a beast. Some friends had chevelles with small blocks and not even close to the same power, I had way more torque and the gas milage wasnt that much worse, I would get 16-17 hwy they would get 17-18 hwy. It is also a much stronger built engine even in a two bolt block.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin ![]() 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
#13 |
Re: 400 BB vs 350
you got 17 out of a BB!
If gas mileage isn't a problem i would go BB. they're more fun and if you like loud pipes it'll definitely do it for ya.
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
#14 |
Re: 400 BB vs 350
it was the late 70s and early 80s the speed limit was 55zzz. The car had 3.31 gears and was turning 2500 at 60mph if I remember correctly
#15 |
Re: 400 BB vs 350
the 402 is a .030 over 396 basically, and in the chevelles it was still called the 396 even after it became 402 in 1969, b/c ppl knew the 396 name they didn't know the 402 name, but in trucks it didn't matter
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#16 |
Re: 400 BB vs 350
are they both all c20's if future may be lowering it you may want a c10but iwould go for an original bb truck if i had the chance
common sense isn't so common anymore |
#17 |
![]() Join Date: Aug 2005
Re: 400 BB vs 350
My burb was a factory 396. First BBC I owned after several 350s. I liked driving the mostly stock 396 more than some of the modified 350s.
#18 |
![]() Join Date: Jan 2002
Re: 400 BB vs 350
Believe it or not, I got 15 in town with a 402 in a 72 sb 3.08 gears. I would buy the big block because you can always convert a 1/2 ton 2 wd later down the road if you want. Oh yeah, just look at my sig, too, you can see my obvious choice!!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#19 |
Re: 400 BB vs 350
Very hard to believe for me that anyone can get mid-high double digit mileage w/any size BB in ANY vehicle, much less a brick shaped truck. Maybe if you drove like 10 mph under all the speed limits and creeped off the lights, I could see a snowball's chance, but I am pretty sure there aren't many of those drivers here. Sorry guys, I can't buy it....I'd have to see that in person to believe it.
I know a guy who drives a 396 LWB everyday....swapped to a 1406 to get better than 9mpg in town...now he gets 10! The motor is relatively fresh and the axle ratio is a 3.08 non posi. On a really good day with a tailwind he might get 12 on the hwy. If you do your math correctly, most of you will find these numbers are very close to what you get unless of course you are running a four speed auto.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#20 |
Re: 400 BB vs 350
I would probably make a decision on the truck itself first and the motor second. But if all other things were equal, i'd go for the BB.
But i wouldnt if the body was in worse shape -- etc etc
Are you retired too? Nonsense! I'm in my prime |
#21 |
Re: 400 BB vs 350
I agree with Streetstar.I`d buy the truck,not the motor.
#22 |
Re: 400 BB vs 350
streetstar nailed it.
#23 |
![]() ![]() Join Date: Jul 2003
My 4.10 ratio equipped C/20 402 usually averages 11. I just installed a new tonneau cover, I might get 12...
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#24 |
Prestige member Old Farts Club
Re: 400 BB vs 350
A friend of mine is into big blocks and he buys them when he can as the early ones are getting rare and expensive .so buy it take it out and preserve it, put in a 383 which can get as much torque as a mild big block and have fun,
Hey sombodys gotta do it! ![]() |
#25 |
Re: 400 BB vs 350
I finaly pulled the trigger. I have been looking for a truck for some time now. Came across this one and could not resist. Its not all original, put has been taken care of very nicely. It has a 402 BB motor and is very clean, sounds great. I feel like a little kid !! Looking forward to summer.
