Old 03-20-2008, 03:10 AM   #1
superman3405
Junior Member
superman3405's Avatar
anti freeze leak
So my truck has been sitting for a while to get some body work done. Under the truck back almost under the cab there is a spot of leaking antifreeze. What back there could/would be leaking?
1972 Chevy C-10 Short Bed (Ol'Blue)
350/350TH
2003 Chevy Silverado Z71
2007 Honda MiniVan...yup we should all be so lucky
superman3405 is offline   Reply With Quote
Old 03-20-2008, 03:26 AM   #2
El Jay
Gone to greener pastures
Re: anti freeze leak
"Freeze" plug on the back side of the block.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-20-2008, 03:26 AM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
the only thing back that far would be your heater lines and heater core. what side it the leak on? if it's the passenger, then it's either of the two I mentioned.
trace the leak if you can to rule out a leaky freeze plug as well.....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-20-2008, 04:09 AM   #4
superman3405
Junior Member
it is on the drivers side right around the oil filter. The freeze plug?? How does that end up leaking?
350/350TH
Old 03-20-2008, 06:09 AM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Some people just run straight water and the steel freeze-plugs (among other things) rust away.
I did this when I was a kid and didn't know that anti-freeze contains a rust inhibiter plus lubricates the water pump.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-20-2008, 06:15 AM   #6
superman3405
Junior Member
are there any other issues other than needing to replace the plug I should look out for? Since the plug busted it would not have any affect on my motor would it? it is fairly new and i would hate to have to pull it
350/350TH
Old 03-20-2008, 06:39 AM   #7
71Farmtruck
Junk Junkie
71Farmtruck's Avatar
If you did not overheat it then no, there should be no issue. If it is the plug fix it, the leak will get worse.
Mike
71 Chevrolet C-10 Short Bed Stepside
81 GMC 1500 Sierra Classic Long Bed
71Farmtruck is offline   Reply With Quote
Old 03-20-2008, 06:41 AM   #8
superman3405
Junior Member
okay, just trying to ease my worries, the truck has not been cranked up for at least 2 months
350/350TH
Old 03-20-2008, 06:42 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and if it is the plug, and if it is caused from rust, stick your finger up in there once you remove the plug... see if there is rust sludge build up... if there is, you'll want to try and remove all of it.
Old 03-20-2008, 06:44 AM   #10
El Jay
There is some stuff called "K-W Block Seal(er)" that works real good. But you have to follow the directions exactly. ABSOLUTELY no antifreeze in the system when you use it. You have to flush, reflush, and reflush the cooling system to get rid of the antifreeze.
After that do EXACTLY what the directions on the can say.
You can run with a leaky freeze plug, if it's not too bad; but check the coolant level at least once/day.
To replace the freeze plug, you're either going to have to drop the transmission, or pull the engine.
If you drop the transmission, replace both freeze plugs on the back of the block. If one is bad, how far behind is the other?
If you pull the engine, replace them all. Refer back to previous comment about "If one is bad....."
Well, I hope I helped you a little bit.
El Jay
Old 03-20-2008, 06:56 AM   #11
cruiserman
Good opportunity to put in a block heater.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 03-20-2008, 07:32 AM   #12
Longhorn Man
true... but shouldn't be needed in Tennessee
Old 03-20-2008, 07:56 AM   #13
superman3405
Junior Member
naa no need for a block heater here. The truck has been sitting for 2-3 months. We had a bad cold spell here back in Feb. so that may have done it. Who knows, I will pop a new one in once I get it painted. Thanks guys
350/350TH
Old 03-20-2008, 06:20 PM   #14
Ole Blue 68
Ole Blue 68's Avatar
Also, if you do wind up replacing those plugs, I'd recommend going with brass plugs. They last longer than the steel.
Ole Blue 68 is offline   Reply With Quote
Old 03-20-2008, 08:56 PM   #15
tcb-1
tcb-1's Avatar
x 2
and they do not rust!
Doug
Old 03-20-2008, 10:39 PM   #16
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
I've noticed that usually the only one to leak is the hardest one to get to
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 03-21-2008, 02:48 AM   #17
Longhorn Man
I totally agree on the brass.
And I also agree, the leaky ones are over starters every time.
Old 03-21-2008, 07:34 AM   #18
Husker
Husker's Avatar
I have one leaking also. If ya take the Exhaust manifold off can't ya get to it ok?
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-21-2008, 09:16 PM   #19
superman3405
Junior Member
Well....climbed under the truck today and this ?#%^$* plug is in the most difficult spot to get to. I think I am going to have to pull the motor. I will deal with that later.
I see there are brass plugs and rubber plugs. Are the rubber ones any better?
350/350TH
Old 03-21-2008, 09:37 PM   #20
70STOVEBOLT
70STOVEBOLT's Avatar
The rubber ones are the expandable type. I would not recommend using that, except maybe as a temporary fix. The freeze plug is there to prevent the block from cracking if the water in the cooling system freezes and expands. The idea is that the plug will pop out before the block cracks. If you use the rubber one, it can't pop out. Freezing would probably not be a problem in TN tho.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-22-2008, 09:43 AM   #21
El Jay
The "freeze" plug is not a freeze plug.
The holes are there to let the sand out of the block casting.
Old 03-22-2008, 04:58 PM   #22
LONGHAIR
While they will let the sand out....technically they are there to hold the cores in place from the outside.
LONGHAIR is offline   Reply With Quote
Old 03-24-2008, 04:01 AM   #23
71Farmtruck
Junk Junkie
Brass is a non-ferrous metal, it cant rust.
Also, if that plug is in a bad place there is a tool you can get that has the plug seater on a swivel so you can whack it in at an angle with a hammer.
Mike
Old 03-24-2008, 08:56 AM   #24
El Jay
Point taken.
I just wanted to make sure that he didn't use a "freeze" plug for cold weather engine protection.
