Old 03-20-2008, 04:15 AM   #1
76CustomDeluxe
Angry Trouble staying running
I have a 87 GMC with a 305 tbi that won't stay running for me. What it is doing lately is it will start up and run for a while, start faltering and die. I try to restart it and it will try and start every once in a while but it will never stay running. If it does happen to start again it will run for a while and then falter and die. I've changed out the fuel pump, fuel filter and one of the fuel injectors and none of that has done any good. Anyone have any suggestions on what it could be?
76CustomDeluxe is offline   Reply With Quote
Old 03-20-2008, 04:25 AM   #2
zombiescustoms
zombiescustoms's Avatar
Re: Trouble staying running
Have you checked the fuel pressure? I'm not real familier with TBI (just bought one myself) but I'm sure there is a pressure regulator up near the injectors, usually there is a vacume line that changes the pressure depending on the load on the motor, if you are not getting enough pressure to the injectors they wont work right and the motor will run like crap or stall.
*** I just looked up the specs on the TBI aparentlly there is not a fuel pressure regulator but the pressure should be between 9-13 psi***
zombiescustoms is offline   Reply With Quote
Old 03-20-2008, 05:13 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
youve checked to make sure that this is a fuel problem and not a spark problem.. do you have good spark after the truck dies?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-20-2008, 02:23 PM   #4
James McClure
One shot, one kill.
Fuel pressure regulator is built into the TBI upper half. 9 to 13 PSI is correct pressure. A quick test to see if regulator has failed is pinch off return line (smaller of the two lines) Best thing is a pressure guage though because you can use the pinch off at the same time to check the fuel pumps ability to excede 13 psi. Be careful doing that though, pump can deliver 50+ psi. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-20-2008, 06:51 PM   #5
old Rusty C10
if the fuel seems ok im betting the distributor or the pickup coil in it although some times ive seen a coil pack do this
Bob
I hate cancer!!
Old 03-20-2008, 07:14 PM   #6
sjarrett71
sjarrett71's Avatar
If it runs long enough for the truck to get warm it might be the ignition module under the distributor cap.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 03-20-2008, 09:04 PM   #7
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Believe it or not.....try replacing the PCV. It has an affect on TBI engine runability....to the point of not running at all. I've done a few.
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
