Old 03-20-2008, 04:34 AM   #1
C-10volvo
C-10volvo's Avatar
Spindle question
Spring seems to be showing here in Oregon now, and I need some spindles for the front but I do not know my brake size. Its a 1984 C10 Scottsdale without any sort of towing package. From that info would any of you guys know if i had the 1" or 1 1/4" rotors? Are they just referring to thickness?
Would you go for DJM or Belltech?
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 03-20-2008, 04:55 AM   #2
slugish
Slugish
Re: Spindle question
Almost sure its 1 in rotor . just take wheel off & measure width of rotor. 5 leaf springs in rear ( not the heavyduty pk. ) usually means 1 in.
slugish is offline   Reply With Quote
Old 03-20-2008, 05:00 AM   #3
slugish
Slugish
Wink Re: Spindle question
oh also both djm & belltech are highly regarded as the best & also western chassis. I didnt do my home work 5 yrs ago & put some cheap ones on my 84 (AIM INDUSTRIES) sO FAR NO problems but I still worry . Not worth the worry , get one of the others.
Old 03-20-2008, 06:08 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Turn the front wheels and lay down on the ground. Take a tapemeasure and measure the thickness of the rotor at the backside of the tire.
piecesparts is offline   Reply With Quote
Old 03-21-2008, 11:42 AM   #5
EN*PN78
EN*PN78's Avatar
Yes, thickness of rotors. I would say measure them first. Take off on wheel and measure. I have a 78 low end 2wd straight six truck. Should of had the 1" rotors. But No someone somewhere at one time decided to go with 1 1/4" upgrade. This is after I ordered my spindles and was putting them on. Huge mistake. I learned.
Also FYI summit racing has the best prices and free shipping on spindles and springs. Also a great return policy.
Bell Tech
Good Luck
EN*PN78 is offline   Reply With Quote
Old 03-22-2008, 02:48 AM   #6
jermasaurus
jermasaurus's Avatar
Djm has better prices that I have found. Their 1.25" spindles were cheaper than the 1" if I remember correctly
You can also get a 3" drop with DJMs spindles. I bought mine from stylinconcepts because summit was on backorder. Prices were about the same.
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 03-22-2008, 06:49 AM   #7
1979 Chevy stepside
1979 Chevy stepside's Avatar
I just picked up the 3" front drop spindles for my 79 stepside and figured i had the 1" rotors also but turned out i had the 1.5" glad i checked first, i went with the 4" rear leaf drop also wish me luck im gonna go bust some knuckles tommorow and attempt the install myself.. not payin some halfwit 800 bucks to do the job !!
Edit ! I went with the Belltech setup and picked up their shocks also figured they needed a change
1979 Chevy stepside is offline   Reply With Quote
