03-20-2008, 06:18 AM | #1 |
Please Help!!!
Ok heres the deal, i have a 1968 chevy truck. long bed fleetside. And i have some crazy wiring issues that i cant seem to diagnose. When i press on the brake pedal my pass. front parklight comes on and so does the right turn signal indicator. And when my headlights are on and i press the brake pedal my pass. side rear goes completely out no lights at all. and i have no right turn signal which could just be a bad turn signal cam or switch. Please help this is my daily driver as a 16 year old so i need it to be reliable. I have already cleaned and made sure i have adequate ground on the lights.
03-20-2008, 06:22 AM | #2 |
Re: Please Help!!!
First make sure all your light bulbs are good. If not sure replace it. They are cheap. Next, make sure all the connections are good. You can unplug em a couple of times and that should do. Next recheck all of your grounds. It sounds like a ground problem to me. I am not an expert but I have fixed a few problems. If this doesn't help I would start checking switches.
03-20-2008, 06:25 AM | #3 |
Re: Please Help!!!
Alright, i appreciate it, many people have told me ground issue and the problem was alot worse before but i still cant seem to figure out this last bug, would perhaps some type of dielectric grease on the fittings do any good?
03-20-2008, 06:25 AM | #4 |
Gone to greener pastures
Re: Please Help!!!
It sounds like you may have some grounding issues.
I'd start checking the grounds on all the lights. I know that sounds like a PITA, but it is FREE. Hopefully, somebody else will chime in with some other ideas. The folks here are great people & always willing to answer questions & help. And their knowledge is encyclopedic.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
03-20-2008, 06:31 AM | #5 |
Re: Please Help!!!
If you have any advice on which lights to focus my attention on please let me know. Thanks again
03-20-2008, 06:39 AM | #6 |
its all about the +6 inches
Re: Please Help!!!
Here is what I would do...
Replace your bulbs. 4 1157 bulbs (same front and back) Now, check this and let us know what you find; I have a feeling your 4 way flasher knob on the right side of the column is broken... and if so, I'd bet they are in the on position, and the flasher has been removed from the fuse block. (there should be 2 round things plugged in, one for the turn signals, one for the 4 ways) Re-check your grounds too... but I don't think this sounds like a ground issue to me. Last edited by Longhorn Man; 03-20-2008 at 06:40 AM. |
03-20-2008, 06:47 AM | #7 |
Re: Please Help!!!
ok i whent out and checked, the flashers work, there are two round things on the fuse block. i have replaced the lights and still no luck. Thanks for the help keep the suggestions coming!!
03-20-2008, 07:18 AM | #8 |
Re: Please Help!!!
Could this be a possible bad turn signal switch?
03-20-2008, 07:24 AM | #9 |
72 Chevelle Club
Re: Please Help!!!
That's what i'm thinking just cant remember how to check it to be sure !! Maybe someone can help out with how to check . Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
03-20-2008, 07:26 AM | #10 |
Re: Please Help!!!
well thankfullyi have a decent paying job and the switched are only 25 buck so i might replace just to be sure.
03-20-2008, 07:29 AM | #11 |
I have a radical idea!
Re: Please Help!!!
It is most likely a bad turn signal switch. All of the light functions (including brake lights) besides headlights run through it. I never knew this until I had some of the same problems with my '67 C-30. The brake light wiring is wired into the turn signal switch so that when your brakes are applied, the light will actually blink instead just being "ON" when you are signaling. A new signal switch fixed all my issues.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-20-2008 at 07:30 AM. |
03-20-2008, 07:30 AM | #12 |
Re: Please Help!!!
I would do that... however, just plug it in without mounting it in the column... if the problem is still there, you can take it back no problem.
03-20-2008, 07:33 AM | #13 |
Re: Please Help!!!
being a new member here i am constantly amazed with how cordial yall' are i appreciate the help 110% a new signal switch sounds like my solution. I'll post a reply as soonas the part comes in and hopefully some pics of the truck Thanks again!!!
03-20-2008, 07:37 AM | #14 |
72 Chevelle Club
Re: Please Help!!!
03-20-2008, 07:40 AM | #15 |
Re: Please Help!!!
i had problems with one of my trucks that seemed to be a lot like yours, i replaced the switch and it solved them all, go for it, I wish i would have known before i tried 1000 other things
good luck
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
03-20-2008, 07:42 AM | #16 |
Re: Please Help!!!
Hey man i know exactly how you feel. I have been trying like hell to figure this out for the past week or so, i'll be lucky if i have any hair left by the time i'm done! but yeah im thinking a new switch is the way to go
03-20-2008, 07:44 AM | #17 | |
Re: Please Help!!!
This is the best message board I have ever been associated with, and the guys on here are second to none. Everybody is willing to help out if they can, and it is a pretty close knit close. We do have one flaw though! We are picture fiends!! So without further ado, Let's see that '68!!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-20-2008 at 07:44 AM. |
03-20-2008, 07:49 AM | #18 |
Re: Please Help!!!
haha i know exactly how you feel, i just got aproved yesterday so im still trying to figure out the site. I'll have em up her hopefully within the hour.
03-20-2008, 07:53 AM | #19 |
Re: Please Help!!!
here she is!
03-20-2008, 07:55 AM | #20 |
Re: Please Help!!!
Oh yeah! Looks like a real clean truck to start with. What are your plans for her?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-20-2008 at 07:55 AM. |
03-20-2008, 07:55 AM | #21 |
Re: Please Help!!!
nice truck, did you get that from Benton, Kansas?
03-20-2008, 07:56 AM | #22 |
Re: Please Help!!!
pic of the engine hope to do an intake this summer, plus some intensive cleaning.
03-20-2008, 07:57 AM | #23 |
Re: Please Help!!!
hahaha yeah i did surprisingly, have you seen it before then?
03-20-2008, 07:59 AM | #24 |
Re: Please Help!!!
i plan on making it a daily driver, im 16 so i need somethin to get around in. Fix the rust, paint it huggar orange with black stripes, black and chrome wheels, mild cam, intake, ceramic coated headers, custom interior. Anyone have any other reasonable ideas?
03-20-2008, 08:05 AM | #25 |
Re: Please Help!!!
yeah, i tried to deal with that guy on that 1970 cst that he has, but it had way more rust on it then he let on, so i just looked at all of the trucks he had, i guess it would have been october 2006, i really liked that truck, but at that time i wanted the most options i could get.
looks like a solid project David
