03-20-2008, 08:26 AM | #1 |
dash lights problem -
I'm having a problem getting my instrument panel backlights to work. I've replaced the headlight switch, the bulbs, and the printed circuit board. I'm not sure what fuse it is in the box, but they all look good. Any suggestions as to what to try now? Also, the gas gauge is working, but not the temp or the ammeter.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
03-20-2008, 08:28 AM | #2 |
Re: dash lights problem -
From what i know on wiring (which isn't much) it could be a bad ground
03-20-2008, 08:39 AM | #3 |
With all the lights not working that might make sense, but I'm not sure where the ground for that is supposed to be. Anybody know?
03-20-2008, 08:49 AM | #4 |
most of the time it is wherever the mounting surface is, i had ground problems with my brake lights and i had to pull the housings and sand down to bare metal.
03-20-2008, 08:56 AM | #5 |
Im almost betting its the instrument panel fuse, they can burn out at the end to where you cant see its burnt out. Also check the instrument feed from the fuse block. if thats not it i would start from the cluster feed and work your way down.
03-20-2008, 09:02 AM | #6 |
Berencam, you wouldn't happen to have an instruction page on how to properly instal a new turn signal switch would you?
Thanks |
03-20-2008, 09:10 AM | #7 |
Ive got a breakdown of every part but unfortunately its in my shop, ill try and see if i can get over there tomorrow and pm ya it. And you are talkin about the turn signal switch inside the steering column arent you.
03-20-2008, 02:51 PM | #8 |
Old member
The panel needs a ground wire attached to it to work correct. Well mine does anyway. I have it attached right by the driver's side with one of the screws that hold the back together.
04-17-2008, 06:39 AM | #10 |
its all about the +6 inches
not likely to be a ground, usually if the ground goes bad, the fuel guage goes out too.
If the tail lights, brake lights, and dome light work, then the fuse is fine. |
04-17-2008, 06:53 AM | #11 |
Chasin' the Dream
Not sure if its applicable on these trucks, but on some vehicles if you lose the tail lights you also lose the instrument lights.
Just a thought. |
04-17-2008, 04:26 PM | #12 |
Active Member
Does light switch have anything to do with this?
I had a problem long time ago with the dash lights and it turned out to be a bad rheostat in the light switch- don't remember what the problem was, though... |
04-17-2008, 07:40 PM | #13 |
Gettin By on Gettin By
http://www.67-72chevytrucks.com/vboa...d.php?t=185665
Heres a wiring diagram. See if your even getting any power at the panel light pin on the cluster plug, then chase it backwards. The diagram is alot easyer to read if you print all 4 out and tape them together. It looks like the brown 20a from the light switch hits both the regulator and the cluster plug. may be a loose connection on the regulator undre the hood. Or a miss wire from an interal regulated alt conversion.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" Last edited by jayharrell; 04-17-2008 at 10:33 PM. Reason: More ideas |
