Old 03-20-2008, 09:59 AM   #1
hewlett2002000
hewlett2002000's Avatar
front end rebuild question.....
ok im working on getting my 66 road worthy. the front end needs rebuilt very badly. it was converted to disc brakes in the front a long time before i got it. ive never rebuilt a front end but i know everything needs to be replaced. the tie rods are bent. i dont even know what all i need. my question is what do i need along the lines of parts, i mean not being factory equipment (disc brake swap)? will everything for a 66 work? if not what can i get that will? if this is a stupid question then please tell me. like i said ive never worked on any front ends. i appreciate any help.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-20-2008, 05:21 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: front end rebuild question.....
You have to know what year the parts are from. If the center link and stuff are 66 then use 66 but if some of the parts are from a 70's truck then you will have to use that application. Good pictures might help in this.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-23-2008, 05:04 AM   #3
bigblock66
john, go with what chevyfleetside said, but i would double check everything else besides the tie rods ends and see if they really need to be fixed. make sure calipers, ball joints, drag links etc.
bigblock66 is offline   Reply With Quote
Old 03-23-2008, 05:17 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
.....when I redid my front end I found out I had some different parts....the different years used different length tie rods. Something to check anyway; I had never done this either but its easy. Just a lot of heavy stuff and pounding!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-23-2008, 05:50 AM   #5
billydonn
Council of the Elders
billydonn's Avatar
Since the change was done years ago, you almost certainly have the 73-87 truck spindles and discs (they are 5 bolt?). It looks like your control arms were not changed from original, since they have grease zerks. Assuming your brakes work okay, a good place to begin is just by changing out the ball joints and tie rod ends. You will need the upper and lower ball joints from 73-87 half ton truck... and probably outer tie rod ends from 73-87. Try tie rod ends from 66, but the outers will probably be too small to fit the 73up spindles. If you don't have a little experience or a good place to do this job safely, go to a good suspension shop... the job can be dangerous. PM me for more help if you need it.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 03-23-2008, 08:13 AM   #6
89 crew
The only dangerous parts of doing the front are the ball joints, (they keep pressure on the springs even when the truck is lifted by the frame). Other than that just make sure the truck doesn't fall on you, and you get everything put back together right. For parts, Unless you want to make lots of trips to the parts store I would take the old parts with me. compare them on the counter. this way you have a new part for each removed old one, and you are ready to reassemble. Watch out for reboxed chinese parts! I got a chinese tie rod for a F800 that had been reboxed. It wore out in 6 months, and soon as it had just a small amount of play it popped off while driving! Turns out it didn't have a full ball on the stud, just a 3/8" tall upside down bowl with a PLASTIC spacer under it!
89 crew is offline   Reply With Quote
Old 03-23-2008, 05:44 PM   #7
joe231
joe231's Avatar
I agree with all of the above, just want to add....once you figure out all the parts, compile a book of all the parts, parts numbers, and years of the vehicles that they fit, it will make it easier down the road, and if you ever sell it the next owner, I'm sure, will thank you for it.
CHEVY ONLY
Old 03-23-2008, 06:57 PM   #8
billydonn
billydonn's Avatar
Thumbs up Re: front end rebuild question.....
Excellent point there! You think you'll remember it all... but you won't.
66 C-10 Stepside
Tremec TKO-600
Old 03-23-2008, 07:37 PM   #9
joe231
joe231's Avatar
yeah, i can't remember what I had for lunch yesterday, let alone what parts I used months ago
CHEVY ONLY
