Old 03-20-2008, 10:20 AM   #1
didsjeff
tires for 66 c10?
this may have been discussed somewhere, but i didnt look through all threads. i have a 1966 c10 shortbox fleetside big window that i bought about three years ago. it came with 205/70/r15 on front which i now need to replace, & 235/75/r15 on rear. as far as i know the front & rear are original with 6 bolt pattern. im not planning on dropping front in near future, but i dont like the wide gap between top of front tires & wheel well opening. i also have old style chrome rims with baby moons that i probably should replace also. any suggestions on wheels & tires that would close the gap in the front?
didsjeff is offline   Reply With Quote
Old 03-20-2008, 10:42 AM   #2
LILRED66
LILRED66's Avatar
Re: tires for 66 c10?
There are so many tire and wheel options available, that it is purely your decision on what size wheel/tire combination you use. You can go with a larger wheel diameter and larger tire sidewall or a combination of both, depending on the look you want.
Many tire stores have a computer program that will allow you to adjust the stance, wheel and tire combination, to see what look you like. You might also try online for the same service. Someone will surely post a link to this website, to allow you to do so.
In any case, good luck in your choice and welcome aboard from Kansas City, KS. Looking forward to seeing your rig posted on the site.
LILRED66 is offline   Reply With Quote
Old 03-20-2008, 07:33 PM   #3
Phildooney
Phildooney's Avatar
Yes I had the same 205,s on the front. Had a big gap so I tried a rear 235 on the front and it looked far better. So I switched to 235's all around and it looks better with a smaller gap. Would like to lower it some more though in the future.Phil.
Phildooney is offline   Reply With Quote
Old 03-20-2008, 08:14 PM   #4
LILRED66
LILRED66's Avatar
On one of my '65 Chevy C10 trucks I have P275/75R15 tires on 15" x 8" Chevy Rally truck rims. There is a 4" gap between the top of the tire and the bottom of the front fender lip. With a 16" rim and/or a taller sidewall, this gap will drop accordingly.
Old 03-21-2008, 07:00 AM   #5
TR65
TR65's Avatar
Didsjeff,
Here is my 65 with the stock stance and 235/75-15 front and rear.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-21-2008, 08:00 AM   #6
LILRED66
LILRED66's Avatar
TR:
First and foremost, welcome to the forum from Kansas City, KS.
Secondly, your rig is one of the finest stock stance rides I have seen in quite some time. You have a real looker.
I also have P275/75R15 on my '65 Chevy C10 lwb fleet, as well as on my '64 Chevy C10 lwb fleet. They are not as flashy or desireable as the swb fleet trucks, but I prefer the stock stance. I think it is ageless and will never die.
Old 03-21-2008, 08:30 AM   #7
66trkbldr
LIGHTMUP,BURNMDWN!
66trkbldr's Avatar
im running 255/70-15 on the fronts and 285/70-15 on the rear.both are on 8" rally wheels. they filled up the fender well in front with out rubbing and they still dont rub with a 3" spring and 2.5 spindel drop. you have alot of room to work with, with these trucks. also did disk brake conversion and was able to find matching gm ralley wheels for 5 lug and 6 lug. fyi
64 LWB Chevy " EL DEVILLE"
61 Caddy ambulance
56 Coupe deville
64 Coupe deville
29 Ford roadster
66trkbldr is offline   Reply With Quote
Old 03-22-2008, 04:09 AM   #8
TR65
TR65's Avatar
Thanks Tony,
I have been admiring your trucks and your work for some time. I'm with you on the stock look and stance.
TR
1965 C10 SWB Fleet
Two owner
Old 03-22-2008, 07:30 AM   #9
LILRED66
LILRED66's Avatar
TR:
Thanks for the kind "attaboy". We are about two weeks from completing the frame-off rebuild on my friend Lee's '66 Chevy K10 lwb fleet. With the exception of Rally truck wheels/caps and red oak in the bed, it will be original, down to the clips, fasteners, radio, in-dash speaker, etc.
I started a topic and will be updating with some new photos of our progress over the past few weeks.
Two thumbs up for the different styles and tastes of those who post here, but I found my place with the stock stance appearance.
Old 03-22-2008, 08:06 AM   #10
Tomsriv
Tomsriv's Avatar
Here is mine fully loaded with 32 x 11.5 BFGoodrich All-Terrainl T/A tires on 15x10 wagon wheels front and rear. It does not rub unless its fully loaded and even then it is only on bumps. I really like the look of these tires. I would like to find something with more of a street tread though since I never take this off-road and its a 4x2. I might have to run Mickey Thompsons to get something this wide in street tread, but it fits under our trucks!
Tomsriv is offline   Reply With Quote
Old 03-22-2008, 08:49 AM   #11
LILRED66
LILRED66's Avatar
Nice roof rack...
