is this a common problem?
i just got my 70 c10 and it needs alot. i was playin around last weekend and found alot of bondo. which sux but its a 38 year old truck so. i wanted a project and i got one, lol... but i have a concerning area. there is rust on the top corner of the inside of the cab on the drivers side. is this common?
Re: is this a common problem?
Not uncommon. You may have some about to pop through over the windshield too.
I have it. It can't be that uncommon. Some companies make a patch panel for the inside of the cab just above the winshield and it wraps around the side a little bit IIRC.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
Cab roof or upper side of the windshield too common. Check also under all the seal lip. Plus under the sealant in the gutter near the drip rail another common spot.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
yea ive found rust just about in all those spots. do u think it would be easier to fix my cab or try to find another?
![]() Join Date: Mar 2005
how are the cab supports and floor boards. i'll bet if the cab is that rusty the floor boards are shot as well, unless someone has already repaired them.i would replace the cab if it was rusted everywhere..imo
yep, try to score a better cab if you can-- all those patch panels would turn into a ton of work
Are you retired too? Nonsense! I'm in my prime |
![]() Join Date: Jul 2003
It is a common issue on the east coast. I would look for a better cab, unless the rest of it is very solid.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
