Old 03-20-2008, 06:12 PM   #1
jorgensensc
jorgensensc's Avatar
Spinner bar question?
I would like to get the ansen sprints, but I would like the spinner bar for a cap (similar to what is available for TTII's) However since it has a pop in style cap and not a bolt on cap like the TTII's the ones American Racing has won't work.
Could I drill a hole in the center cap and use a bolt through it and screw on a tribar spinner of some sort? I thought I saw someone do something using this idea and truck ralleys? Where could I find a screw on type center spinner? Thanks in advance guys!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-20-2008, 07:00 PM   #2
Myself
Re: Spinner bar question?
I bought a whole generic spinner setup from my local tire shop for $40.00. They are the type that go on first, before you put on your wheel. The wheel holds the cap on. Then you screw the spinner to the cap.
Myself is offline   Reply With Quote
Old 03-20-2008, 07:05 PM   #3
Myself
Like this!! The caps come in different sizes, depending on the wheel center hole.
Old 03-21-2008, 04:52 AM   #4
Boog
laying low
Boog's Avatar
I have a set of spinners I bought to go with my American Outlaw 2 wheels. The metal cap is like the ones Myself posted. My spinners are the straight 3 bar instead of the swept 3 bar he has. They attach with a center bolt and have a set screw in the side of the spinner to snug it to prevent spin off. Most custom wheel dealers can get you the spinners although not all want to fool with them. All he has to do is call his wheel supplier and they will know what will fit the wheels. I told my dealer I would buy the wheels ONLY if he could get the spinners to go with them. He did.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-21-2008, 05:52 AM   #5
straitnate14
straitnate14's Avatar
if you have the patiance you can use a welder to make "tits" for snap in center caps, but if you like me you would do it to all 4 corners before you relize mini moons wont fit on the front because of the dust cover on the axle.. this was a 5 hour mistake and now I have the 4x4's back on my 2WD but I took the sticker off and pollished them I was more than a little bit mad and left my truck up on the jackstands over night as punnisment for not telling me
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 03-21-2008, 06:40 AM   #6
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
You could also drill and tap the wheels and mount them on the outside . I used to have slots with the centers bolted on like Torque Thrusts ! Just a thought.
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
